Question about Canon Digital Rebel XT / EOS 350D Body only Digital Camera
Error 01 the apperture of the lense does not open when the camera is being shot
    Champion:
    Scholar:
  • 216 Answers
What camera is this?
If DSLR, that out the lens from body. Look into the lens, is aperture is closed or opened? It should be open on Canon and open or closes on Nikon(make sure you can turn the Aperture ring).
atdlee@netzero.com
Posted on Jan 01, 2008
How to fix err 01
you have a faulty connection between the lens and body of the camera
  • remove the lens clean contacts on lens and the body of the camera
  • remount the lens
  • if you still encounter the error turn off the auto focus switch .
  • take a test shot (manual focus)
  • if you did not encounter the error your lens might have a faulty flex cable have it checked / replaced at the service center
Aug 24, 2014 | Canon EF 50mm f/1.8 II Lens
Error 99 in canon
f7.3 maybe out of range for automatic function on camera lighting conditions.
Feb 08, 2012 | Canon Cameras
Currently have sigma 28-80mm 1:3.5-5.6 and 100-300mm 1:4.5-6.7 lenses both 55mm that I use with my Pentax MZ-50. I would like to purchase a DSLR camera and rather than waste the lenses I already own would...
before buying ask the sigma salesman or dealer about it, i know only for nikon camera- it's lenses are compatible for all camera, digital or film base slr cameras.
Feb 12, 2011 | Sigma 28-80mm Mini Zoom Macro Lens
Hi error 01 on canon 5d mk 1. With brand new 70-200 2.8? Have read there is an issue on portrait shots but I am unable at this stage to be sure if it has only been an issue for landscape horizontal use or...
Error 01 is generally associated with camera unable to communicate with lens. Could be contacts need cleaned; since lens is new contacts on camera are more likely starting point for cleaning. But, common issue is failure of something in the lens, but that seems unlikely as it is new ... but it could happen. You might search for other Canon Error 01 comments/solutions. Failing a solution from that, time to contact SigmaUSA repair to have them inspect/repair under warranty.
Oct 03, 2010 | Sigma APO 70-200mm f/2.8 EX DG HSM Lens
Every shot is very dark
If every shot is very dark, make sure to set the apperture higher and a slower shutter speed. This will allow your camera to acquire more light coming in to the camera.
Jul 26, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
F-- keeps on appearing on my apperture?
the F-- actually means the lens is not fitted to the camera properly as far as i know. if you turn the lens and fit that properly once again, it should work
Aug 07, 2009 | Nikon D90 Digital Camera with 18-105mm...
E:91:01
No Problem! Press MENU end go to setup, choose initialize to initialize the cam and put all the configs! finish! your problem is over.
Sorry for my english because i'm from Brazil ^^
Mar 06, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Error E:01:00
I have had the same problem with my camera. After some years without any reason the message E:01:01 appears on the screen and the display shows only black.
I dissamble the camera, clean all contacts and after assembling the camers does works as before.
Oct 19, 2007 | Sony Cyber-Shot DSC-F828 Digital Camera
Canon digital rebel xt :error 1 message
I agree with dovi. I actually emailed canon and here is what they said and how to do it; Thank you for your inquiry regarding your digital SLRs. We value you asa Canon customer and appreciate the opportunity to assist you, and I'm sorry to hear that you're running into the "error 1" message. From what you mentioned, it sounds like the lens might be having problems communicating with your cameras. One thing you could try is toclean the contact points on your lens and your camera. If you have not done this yet you can do so by turning the camera off, removing the lens, then brushing those copper points on both the lens and the camera body with something like a clean eraser. Should problems continue, I would suggest that you go to a local camera shop and try a different lens. That way you can determine whether the problem is due to the lens or to your cameras. I hope this is helpful Jason
Sep 04, 2007 | Canon Rebel XT / EOS 350D Digital Camera
W1 Making noises....??
The W1 uses metal rings that slide in place with a tiny hole in the middle to give the required apperture it does not have a diaphram that closes and opens to give the apperture... so what you here is the sound of changing the suitable ring ( or disc) with the apperture ... You can look in the camera (lens side) and change appertures, you should be able to see this happen ... don't click with flash though :) The sound is very low though if you here a loud click there's something wrong.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Open Questions:
See all Canon Digital Rebel XT / EOS 350D Body only Questions
Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
308 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
