Question about Samsung SC-D107 Mini DV Digital Camcorder
Shutter dosen't open, Black Screen while recording
I've had this camera for about 3.5 years, recorded only about 7 tapes, recently i tried to use it and would not record. I tried to take still pictures and i can hear the sutter but again nothing gets recorded, all what i see is dark picture, video or still image.
The camera still plays ok, from SD card or tapes.
Any ideas?
  • Anonymous Jan 04, 2008
    hi i have the same problem could anyone help me please
  • 3 Answers
There is a couple other posts on Fixya regarding this issue, the CCD sensor going bad and resulting in no image. i have the same issue and i just stumbled on the (yet to be verified) solution. if the settlement is legitimate then Samsung will repair for free! (and refunds for people who already paid Samsung for repairs). the site asks for contact info but i worry about scams so i'm going to contact Samsung directly.
i hope this is real!
The affected models include:
SCD 23, SCD 27, SCD 103, SCD 107
Posted on Dec 10, 2008
I can record audo but no video..shutter doesn't seem to open
try cleaning unit with rubbing alcohol and qtip the head and let throughly dry before use!!!Good Luck to You!!!
Jun 25, 2009 | Sony Handycam DCR-TRV130 Digital Camcorder
Sony 8mm camcorder will record sound but no video
Since it is playing the tape, the play head is ok. Now recording is done by recording heads so you may have a clogged heads or damaged recording heads. Try to clean the heads with head cleaning tape to see if it would help. 1. remove the tape and leave the door open. 2. using a canned air, blow out any dusts in the tape area. 3. run head cleaning tape for about 10 seconds and no more. 4. try the recording.. If this does not resolve, you may have a damaged or heavy clogged video heads. Take it to nearest video technician for a diagnostic. -James
Mar 28, 2009 | Sony Handycam CCD-TR517 Camcorder
Images not recording
I have a sony 14E and suddenly it stopped playing and recording. With vertical lines on the screen I knew to clean the heads. No effect on the recording/playing malfunction.
However I persevered and it seems to have worked in it is now recording and playing back. The steps I suggest, with PERSEVERANCE, are :
1. Clean the heads (I did it 3 times in all, with about 1 hour between each session);
2. Leave the camera open (tape section) for about 2 hours and put the camera (with or without tape) in a warm place. (I also had condensation messages).
3. Once it is warm put in a recorded tape and attempt to view it. At first I had "dirty" vertical lines for a few seconds but it cleared and played normally.
4. If Step 3 still does not work repeat 1 and 2. As I said PERSEVERE.
If Step 3 works then try to record. It should work hopefully. If not, repeat 1 and 2 (shortening the "Warm Up" time).
Good luck. I hope mine continues to work OK now. It is to do with dirty heads and coldness I think.
Jan 03, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
Canon SD 550-- sensor problem? Bought 3/2006 and have had no problems. Suddenly, LED screen went black--shows nothing and cannot take a picture altho will flash and record black picture. Shooting...
The shutter of the camera is not opening that is why every picture taken is recorded black. It is a mechanical problem and probably has nothing to do with the sensor. Not very expensive
Aug 30, 2008 | Canon Cameras
Help With My Digital Video Camera!
You try it with proper connection using a new or working wire if you have used a vcr to play back.
Play the tape with any other camera.Bcoz your monitor may be fault.
Play the head cleaning tape in the camera, and try
May be the recording head of your camera is clogged
Mar 29, 2008 | Photography
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
JVC grey screen
Normally there are two reasons for the given problem. 1). Bad or defective CCD. and/or 2). shutter not working. in the first case the only solution is the replacement of the CCD. and in the later case sticking of shutter blade, non functioning of shutter blade will cause the problem. This can be rectified by sending it to some repairer.
Sep 13, 2006 | JVC GR-D31 Mini DV Digital Camcorder
Samsung SC-D107 Mini DV Digital Camcorder Logo
185 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
