Question about Metrologic Instruments Voyager BT MS9535 Handheld
Default Barcode as the one used in the manual
I want to create a laminated scan card with various core functions directly out of the programing manual.  To do so I need to know the name of the barcode format the Metrologic uses for the instructions set forth in the manual and from which you can directly scan.  In other words, what barcode format does Metrologic use in their manuals to be able to tell the reader how it is to be programed?  I'd love some help with this.  storm@stormjenkins.com
THANK YOU IN ADVANCE
  • StormJenkins Jan 06, 2008
    Thanks for offering to take a look at the barcodes.  I am attaching them in a jpg.  I wasn't able to email them to you as I could not figure out how to locate your email address, so I hope this makes it way to you.  I would normally just cut and paste them out of the manual, but many of the barcodes I want to include on the laminated cards are custom, so c&p isn't an option.  If you can determine what barcode format the attached file contains, I'd be grateful.  I have emailed Metrologic four times, but they don't answer.  If you can, please email me the response, as well as posting it.  My email address is shown with the barcodes in the attached jpg.  Thanks!  Storm Jenkins
    I may have failed to properly attach the jpg to my last post.
I finally figured out the problem, thanks to Here4you's help.  The Metrologic VoyagerBT does indeed use the 128 barcoding protocols.  The reason my barcodes were not scanning in properly is that the correct barcodes had a hidden "Function-3" prefix, which all of the scanner's programming codes have.  I am still having trouble figuring out how to input a "Function-3" prefix into the various barcode generation programs I am testing.  I use Macs, not PCs so many of you may be inclined to recommend certain programs that are are exclusively made for PCs.  I will be creating the data for the barcodes in either Excel or Filemaker, so I am attempting to input the ASCII equivalent for the Function-3, with mixed results.  Thanks for the help!
Posted on Jan 09, 2008
  • 25 Answers
I don't have a manual with me tonight .. but I think its a code 3 of 9 with a twist. If the codes in your manual only have 2 barwidths (narrow and wide) my memory is correct. If there are more than 2 barwidths its c128.
A standard c3 of 9 barcode has a start-stop pattern that decodes into an '*'
When '12345 is rendered into a C3of9 barcode the code actually holds *12345*
Barcode readers spot the code by looking for the *. Metrologic's codes are using a different start stop pattern. Again if memory services me they use a '#' so this makes the code "unreadable" by all but a verifier. It also means that most barcode production programs can't print it ...becuase they impose the standard for start/stop patterns.
The easy way to create one of those cards (for Metrologic) is to forget all the yadda I'm giving you. Instead figure out which pages you need . Next copy the pages of barcodes you used to get the setup correct. Then do a cut and paste job onto a blank page of paper. It goes quite quickly and the barcodes copy well.
If none of that helps then PCscan a page of codes in your manual and email the image to me. My eyeballs are (sadly) calibrated to read barcodes and I can quickly tell you what you've got.
Good lucuk
Posted on Jan 05, 2008
  • Daniel Lind Jan 06, 2008
    My highly calibrated eyeballs can tell you with certainty that is a Code 128. ..my calibrated eyeballs cannot tell if it is mode A,B, or C. .. but my verifier can from your jpeg.
    I'll email you Tuesday with the content it you'd like. I will print them and then scan them with a verifier. ... and hand the results back to you.
    FYI I'm in the midwest. My email is danland@sbcglobal.net Please retransmit your codes to me in JPG.
  • Daniel Lind Jan 09, 2008
    I still haven't received received your jpeg so I'm hoping knowing it was C128 has helped you move forward.
    Regards,
Symbol ls1902t-1000 scans extra characters when scanning a barcode
Download the quick start guide from support.symbol.com and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Oct 29, 2012 | Symbol LS1902T-1000 Handheld Laser Barcode...
After scanning it is automatically not going to the next line
Symbol barcode scanners by default do not add a return after a scan. You need to program the scanner to add a suffix.
Download the manual from Motorola/Symbol here
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf&sliceId=&dialogID=219596399&stateId=1%200%20219598121
-Print Pages 224 and 225
-Scan the Barcode "Scan Options"
-Scan the Barcode " "
-Scan the Barcode "Enter"
Scan a barcode
Feb 26, 2011 | Symbol LS2208 Handheld
How to enable an enter for the ms4407 scanner
Create barcode with number 7013 in any program that can create Code128 barcode. Print it out. Check manual page 12-5 and scan <Data><SUFFIX 1> barcode and after that printed barcode witn 7013 number. It works with my MS4407.
Dec 27, 2010 | Zebra MiniScan MS4407 Barcode Scanner
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
How do I get my scanner to go to the next line/box when using Excel?
In your programming manual there is a barcode scan that needs to be scanned in that adds the carriage return function. To do this you will first need to scan the barcode to put the unit into program mode, then scan the carriage return barcode, then scan the end programming code. Now when you scan a barcode the scanner will add the return to the sequence it sends to the computer. If you can't find your programming book you can download the sheets from the Symbol web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 14, 2010 | Symbol LS2208 Handheld
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Quickscan 6000 will read not read programming barcodes
usually there is a laminated like square piece of paper that gives you 4 options to scan and one of them is auto
Jun 06, 2009 | PSC QuickScan 6000 Plus Handheld
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
Enter function
Hi Lee,
It can be done by programming the scanning the 'Send Enter Key' barcode twice, from the owners manual.
eg
Scan the barcodes -
Send All Data, Send Enter Key, Send Enter Key, Save
Oct 17, 2007 | Symbol LS 4278 Barcode Scanner
Metrologic Instruments Voyager BT MS9535 Handheld Logo
364 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
George Etukudo
George Etukudo
Daniel Dollive
Daniel Dollive
jackcity
jackcity
Level 1 Expert
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
