Question about Aiwa NSX-AJ70 Shelf System
Double cassette deck inoperative
Anytime the unit is switched on the secondary deck clicks 8 times, and it stays frozen in what appears to be play/pause mode. Both decks will not respond.
    Problem Solver:
  • 37 Answers
Im sorry but your deck is broken but give this a try get a tooth brush and clean the inside of the tape deck make sure u clean everything
Posted on Dec 31, 2007
How do I dub using the onyx double cassette deck?
There should be a button or switch that will select the recording deck and the dubbing deck. You put a blank tape into the recording deck and the pre-recorded one into the play deck. Pressing the record button on the dubbing deck, on some models should start the play deck running. If not press play on that deck.
Jun 05, 2014 | Sony TC WE435 Stereo Dual Cassette Deck...
I want my teac w600ro pla y deck a then deck b then stopyt
The unit needs work but it might not be worth repairing- that is up to you but most dual cassette decks were very poorly made units. That is why I always steer people away from them. I worked at Teac in Chicago and in fact still work on decks now under the skywave tape deck repair if you were to look me up.
Apr 16, 2014 | Beltronics TEAC W-600R Home Double...
No sound from microphone through speakers
in win vista/7/8 u need to right click the speaker -> recording devices -> double click microphone -> listen tab -> check listen to this device
Nov 18, 2012 | The Singing Machine DVD/CDG Karaoke System...
I have had my 1991 lexus ls400 for a couple years now and I've been using the cassette deck in the stock stereo unit all the time by using one of those cassettes with the 3.5mm headset wires coming out...
The tape deck in the unit probably needs to be fixed. Even though you are using an artificial tape supplying a signal to the heads, there are still motors and belts running in the unit if it thinks a tape is in there. Now a belt or a motor has failed and the deck will not stay in tape mode. Thus pulling the unit out of the dash and having it serviced will be required to use this I pod function. There has to be easier ways to do this- I would consult Crutchfield about it.
Nov 08, 2012 | Audio Players & Recorders
Pioneer Stereo double cassette deck Ct-W302R - is it repairable?
They might be repairable but usually at a cost that exceeds it value. Who wants to pay $150 to fix what was known as a throw away tape deck? Not many. It might even exceed $150 as they are complicated to repair bot being designed to be repaired.
Mar 22, 2012 | Pioneer Audio Players & Recorders
it sounds like your tape heads are worn they will strip your cassettes every time and give you very poor sound reproduction it can be repaired but costly to be honest you would be better off with a new deck and it will be cheaper all round.
Mar 27, 2011 | JVC Audio Players & Recorders
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
I have a TEAC W-450R Stereo Double Reverse Cassette Deck. For some reason, the REC/PLAY II side will not operate. It has not for some time. In fact, that is why I believe I mothballed it some years ago....
I have not seen those to a large extent due to their value not being worth a repair. I did work on them at Teac though. The capstan motor of the right side deck sound like it is burned out. I have some motors here so it is just a matter of if you want me to work on it or not. I get a lot of units in all the time- I am Skywave Tape Deck Repair in Chicago area.
Feb 22, 2011 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Cassette Stuck in Sony Hi-Fi RV-888d
Actually when audiotape struck (Click-Click-Click), rewind and forward 2-3 times or manually rewind and forward 2-3 times with the help of pen. After you can play the cassette
I am also use the same music system (MHC – RV 888D)
Mar 21, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Aiwa NSX-AJ70 Shelf System Logo
167 people viewed this question
Top Aiwa Audio Players & Recorders Experts
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
