when the valve inside the unit turns on to fill the ice maker with water, water leaks from the bottom right side, the leak itself is not visable, as it's inside the sealed frame of the unit
Ice maker is making ice. However, it is making a loud noice and the light turns off and on sort of...
(More)
Ice maker is making ice. However, it is making a loud noice and the light turns off and on sort of like the power is cutting off and on.
I have a GE Monogram refrigerator and the freezer side works fine but the fridge side is getting...
(More)
I have a GE Monogram refrigerator and the freezer side works fine but the fridge side is getting hotter and hotter. Lights fans and what not work, but will not cool. I had to unplug it because the fridge side got so hot (118 degrees).
Any suggestions??
There is mildew building up inside the unit. My company has the exact same model and it has no...
(More)
There is mildew building up inside the unit. My company has the exact same model and it has no mildew. I assume that the internal temp is too high, but don't know why. This is a zdi15c under-counter ice maker.
Cleaned the unit, stopped making ice pump is running but still no ice. Is there a relay that picks...
(More)
Cleaned the unit, stopped making ice pump is running but still no ice. Is there a relay that picks up the compressor, have not heard it sngage yet.
I have the same problem. All of a sudden I hear ice crashing on the floor and the ice maker is...
(More)
I have the same problem. All of a sudden I hear ice crashing on the floor and the ice maker is kicking out ice non-stop. I open the door and it stops and notice that it starts again when I push the door light switch. I opened the top panel and disconnected the wiring plug and it stopped. I reconnected it and now it doesn't work
