Question about E-Mu 0404 Sound Card
No sound in my pc
Even after connecting speakers there is no sound in my pc
    Problem Solver:
  • 37 Answers
Alright first are u sure they are connected coular codedly if so go to the control panel on the start menu the go to sounds and audio devices first off make sure mute isnt on then make sure bar is all the way to high then go to speaker volume make sure left and right are at the far right now at the top off the sounds and audio devices there are five tabs click on audio then then on sound playback press volume and then make sure the volume is at the top for all and balance in the middle for all and make sure all the bottom boxes are not ticked then try a song on your computer and see if it works (it could also be the program u play music on so if it doesnt work try going to another programme and play a song if it doesnt work email me at mid.nightclub@hotmail.com
Posted on Dec 31, 2007
I have no sounds on my pc?
Have you checked to see if you accidentally muted your speakers?
If that is the case then you can go to Start-Control Panel-Sound and see if the speakers are muted.
Did you have any external speakers connected to it?
If you said yes then they may be unplugged or turned off, or they may have died and you could always go back to making your pc the default speaker.
Go back to the control panel and click sound, here you can disable your external speakers to see if your pc can emit sound.
If that does not work then you may have to reinstall the driver for your sound card or see if your computer even sees your sound card.
Mar 28, 2011 | Dell Dimension E510 PC Desktop
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
I have intel pentium (R) 4 cpu 2.80GHz but its sound is not working meanz the usb port is working if we use headphones on it then headphones are working but speakers are not working i tried every type of...
If the headphone is working,
and you are connecting a compatible pc speaker to the same green port at the back panel of pc,
and if the connecting cable is not faulty,
speaker should work.
Make sure speaker is powered on
Also check the same speaker with another pc if it works.
Oct 10, 2010 | Computers & Internet
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Sounds both in head set and speakers
Solution:
i) try somother headset(if you have spare ones...with u), if prob still exists there must problem with sound port(inbuilt sound on your laptop) which is not allowing the wire or chord of your headset to completely plugin to your laptop sound port.....
it is like this  connecting wire is  paritally inside your laptop sound port and partially outside and leading to sounds from both laptop speaker(builtin) and the headset you are connecting.....
Thanking you
M. Sridhar
Dec 26, 2008 | Compaq Presario 700 470024-192 Notebook
LOgitech x230 - problems with sound
If the sound only happens when sound is being played through them I would check the shielding on your connections to your sound card. Make sure that any protective coverings are in place and that the connections are tight.
If it happens at random times even when sound is not being played through them I would see if you are picking up interference such as a close cell phone, fan, ham radio operator, etc.
Dec 18, 2008 | Logitech X-230 Computer Speakers
How to avoid sounds heard in speaker even after connecting headphone in compaq presario c700
Asalam u alikum,
Dear friend yours broblem have been solved if you do this steps.
1. first go to the start menu.
2. then select a control panel.
3. In control panel select option (sound,speech,audio devices) then select change the speaker setting, the sound and audio properties is opened, go to the speaker setting select advanced option in advanced option change the speaker setup and select stereo headphone and apply it.
I hope its solved yours problem.
Thanks
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
Connecting Creative Gigaworks S750 computer speakers to panasonic plasma tv
This depends on the audio system setup designed on your television.
Most speakers can have adapters bought for them which will allow you to connect your speakers to a television. But not every TV will support the 7 speaker configuration with PC Speakers.
The good news is the adapters are fairly cheap at Radio Shack and should not set you back more then 10 bucks. Maybe even cheaper.
Aug 30, 2008 | Acer Aspire 5100 Notebook
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
E-Mu 0404 Sound Card Logo
55 people viewed this question
Top E-Mu Computers & Internet Experts
David
David
Willem.
Willem.
Steve
Are you an E-Mu Computer and Internet Expert? Answer questions, earn points and help others
