Question about Delphi Roady XT XM Radio Receiver
"antenna" problem. I just installed my XM radio in my car.  It worked fine until i had to re-position the antenna wire.  While i was moving it to another location in my car, the wire snapped in two pieces.  I electrical taped both pieces back together, but now my radio says "antenna."  Wouldnt electrical taping it fix the problem?
  • 689 Answers
Satellite Antenna cables are very sensitive. Once the live core expose outside of its shield it will reduce the quality of reception. Live core always should be shielded. Best thing is the changing entire cable from radio to antenna. But if you wish you can try to repair the snapped area by putting isolation material (can be electrical type) but live core (the center wire) should be shielded. You can use aluminum foil as shielding after isolate the live core. Aluminum foil should be contacted the shield of the cable (outer surrounding wire)
Good Luck
Posted on Dec 31, 2007
I have XM radio in my chevy malibu. Worked fine
I believe when the antenna loses power it does not show it on the screen sounds like there might be a break in the antenna wire or simply came out of socket in the rear of the radio.
Nov 03, 2009 | XM Radio (XMP6000)
XM radio ''NOT READY'' message
I have had this problem at least a half-dozen times, and the simplest solution is to pull the 2 fuses labeled 'audio 1' and 'audio 2.' It resets the radio, but it will work for a while after that (until I have to do it again). Had the xm unit replaced 3 times, new antenna installed, replaced the antenna connection wire - it always dies within a month.
Sep 24, 2009 | 2008 Hyundai Veracruz
No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
Sep 02, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
No signal
Here is a site that cares a lot of sat. radio things
http://www.xm-radio-satellite.com/
This maybe what you are looking for a "Delphi XM Radio Wireless Signal Repeater System"
May 08, 2009 | Delphi SKYFi XM Radio Receiver
XM radio reception issues
If you have the magnetic antenna, check it for a little nick on the cable on the outside of the car where water might get in to it. A little water can short the ground and the antenna wire. You also can wash (with lots of water around where the antenna cable is) and see if it happens again, then you will know it not just the weather
Mar 05, 2009 | XM Radio Audio Players & Recorders
Xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
Aug 09, 2008 | XM Radio (XMP6000)
"Antenna" prompt
your sure connect antenna is bad that is why you get this message or you have something hooked up wrong check the power and ground on the unit if it has one .... some have it, some dont but most of the time its just a bad wire
Jul 27, 2008 | XM Radio (XMP6000)
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Delphi Roady XT XM Radio Receiver Logo
194 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
