HI Hi That means the pump needs to be primed by running water through the wand. Push the water button. You will hear the pump change tone when it primes and the light or message will disappear. If you have a restriction in the steam tip the message will not go away.
our Cafe Swiss S.I. Cs100 Typ 790 isnt working right. the wand has been clog and doesnt work. WHen I...
(More)
our Cafe Swiss S.I. Cs100 Typ 790 isnt working right. the wand has been clog and doesnt work. WHen I press the steam button or water button it drain from the back somewhere, what can I do? we have took off the little tip and used a pipe cleaner and cleaned some, but at the bend of the wand is where I think the clog is. (someone didnt clean it and left it all clogged up) anyway, If we cant fix it on our own where can we find someone to service it in Mansfield, Texas?
Hi, I have a Royal professional machine. The little valve in charge of frothing the milk is not...
(More)
Hi, I have a Royal professional machine. The little valve in charge of frothing the milk is not strong enough for getting the milk all the way up, we tried changing the plastic tube thinking that could be a perforation but it still not working, what else can it be? Thanks Keyla
i have a saeco royal professional that I purchased 1 yr ago. Never used the cappuccino maker, tried...
(More)
i have a saeco royal professional that I purchased 1 yr ago. Never used the cappuccino maker, tried it this weekend but nothing happens. Seems like there is not enough power to pull up the milk. What do you think is wrong
