Question about Samsung HLN617W 61" Rear Projection HDTV
LINES ROLL THROUGH THE PICTURE
Straight lines roll through the picture on a 45 degree angle. This happens on all video inputs except the DVI input. My DVD player fed through the DVI cable is perfect. The lines are kind of like morray patterns but they are stright lines that roll slowly through the picture. I changed the bulb last month then the line problem started shortly afterwards.
  • Anonymous Jan 02, 2008
    Hello I am currently experiencing the same problem with my Samsung 61" DLP TV (model HLN617WX). I have horizontal line banding in the S Video and Video inputs. The Component and DVI are fine. Could you please tell me what board you ended up replacing in your TV?
  • Anonymous Jan 09, 2008
    Do you think the problem might be the analog board part number BP94-00434A and not the digital board part number BP94-00385A? The reason I ask is the inputs that are giving me problems are the RF, video and s video. The component and dvi are fine. Looking at a block diagram the component and dvi go to the digital board. thanks for your help.
    Scholar:
  • 170 Answers
If you have lines goin thru your screen you can email scott201201@yahoo.com for info on repair.
Posted on May 25, 2011
HAD SAME PROBLEM. REPLACED SURFACE MOUNT CAPACITOR C655 ON DIGITAL BOARD.
LEE. S
ADDISON COMMUNICATION INC
Posted on Sep 30, 2008
  • 87 Answers
If video is good on DVI input, the problem is only the digital board. Cost to fix by a professional approx $400. Just watch it on DVI or use a high end stereo reveiver to switch digital inputs to DVI. The DMD board is not bad if any input is good
Posted on Jan 03, 2008
  • 97 Answers
Do you use a line conditioner for your AC? It can be any one of your lines or amnother componenet causing a ground loop to occur. Disconnect all cables to unit and see if it still visable. This problem is similar to 60hz scroll on a input that is partially grounding. The HDMI is isolated and the only clear signal due to it.
Posted on Jan 01, 2008
  • 579 Answers
Not to discourage you, but here is an extensive thread from other Samsung owners with similar problems:
forum.ecoustics.com/bbs/messages/2/77447.html
Sounds like the digital/DMD board has noise in those modes.
hope you are under warranty
I have a 42 inch Panasonic viera comes on sound is there everything works except picture. Sometimes I have lines of color flash on the screen what's going on.
Replace the video cable and make sure your video input is matched properly with the audio (audio on input 1/video on input 1) or whatever input you are using.
Feb 25, 2015 | Panasonic Televison & Video
Tip
I get excellent TV sound and blurry picture with lines on the TV side. When i...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Nov 06, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Philips projection dvi problem
The set is old enough (based on model number indicated here) the DVI input (supprised it has one) it will not work with newer equipment.
Apr 15, 2012 | Philips 55PW9363 55" Rear Projection...
Black, Red and yellow triangle in upper right corner of the scrn.
YOU HAVE A CONVERGENCE PROBLEM IC'S WILL NEED TO BE REPLACED. THE FACT THAT THE LINES DID NOT MOVE WHEN YOU TRIED TO ADJUST THEM CONFIRMS IT.
Jan 19, 2009 | Toshiba 57H81 57" Rear Projection...
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
Rolling screen
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Mar 28, 2007 | Mitsubishi WS-65413 65" Rear Projection...
Samsung HLN617W 61" Rear Projection HDTV Logo
329 people viewed this question
Jerry Greenberg
Jerry Greenberg
