Question about Canon PowerShot SD10 / IXUS I Digital Camera
Camera hot but won't turn on after E18 fix
I had the E18 error, and took my SD10 elph apart as in the instructions. Now the camera won't power on. It seemed hot, though, after I'd had the battery in for awhile. Now I put the battery in again and it's not getting hot right away, but I'm not going to leave it in overnight. Any ideas?
  • 3 more comments
  • Joodge Dec 31, 2007
    Just charged up the batteries, and they worked before the repair, too.
  • Joodge Jan 01, 2008
    Nothing lit up when I put in the battery--nothing happened at all. Nothing happened when I powered on.
    Can I keep the battery in while I'm repairing to keep testing it? Also, there's a rubber circular piece that fell out when I was taking the camer apart. I think it goes under the power button, but then it seems too tight.
  • Joodge Jan 02, 2008
    I give up. I may have damaged one of the orange ribbons that are on the reverse side of the battery compartment. I'm going to get a replacement on ebay.
    Thanks for your help.
    President:
  • 1,944 Answers
Did you make sure that your Canon has fresh batteries and it is in recording mode.?
Posted on Dec 31, 2007
  • 3 more comments
  • Damen Wong
    Damen Wong Dec 31, 2007
    Did you follow this guide when you took your camera apart?
  • Damen Wong
    When you put back in the batteries...is there anything happening with the camera? Is there any noise? Does anything light up?
  • Damen Wong
    Damen Wong Jan 01, 2008
    I know you probably don't want to do this but you need to open up the camera again and see if everything is in place. Maybe something got moved/disconnected/broke when you took the camera apart. Check the power supply area...near the battery compartment.
  • Damen Wong
    Technically you can do it...but just be very cvery very careful...
  • Damen Wong
    Damen Wong Jan 02, 2008
    Sorry that I couldn't have been more help. I hope it works out for you.
My canon power shot sd630 fell down and the lens does not function.it says lens error, restart camera.where shall I take it for repair and how much it costs to repair
You could try you local electrical or photo retailer but I'd get a quote first. I don't intend to be rude but its likely the repair could cost more than the camera is worth.
Mar 14, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
I have a lens error, restart camera. How do I restart camera?
lens error,as the lens unable to function normally,becauz the lens movement is arrested due to the failure of the gear box,guide and guide-pins damage so contct camera tec.
Mar 07, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Dec 21, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Y Canon Power Shot SD400 digital Elph camera won't shut down
Your problem in your lens...Try to bring service center. Cause, canon lens it for me it not easy to disassembe dan assemble it again...Different with other camera lens, like KODAK and Samsung.
At sony camera "E18" can be "Turn the power off and On again" like my Sony W.35
Aug 22, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Dropped camera- lens will not go back in-
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera will not stay powered up and lens won't come out
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 15, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
I have a canon power shot a410 model and yet it has a E18 error,, can u help me fix this problem???
Here is a web site that tell you all about the error and how to attempt to fix it. If this has been helpful to you , Please vote.
http://www.e18error.com/repair.html
Dec 20, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
E18?
Click here for help on repairing e18 error
good luck my friend!
Hope you will save 150$ for the repair..
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Canon PowerShot SD10 / IXUS I Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
