Question about Linksys Wireless-G WRT54G Router
No internet connection
I own a Linksys wireless-G model wrt54g v-8 the problem is that I do get wireless signal from the router (full bars) but I can not get internet access on my laptop. I also tried plugin in the ethernet cable to the laptop and still dont have internet access.
  • 589 Answers
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the softwareno internet connection - 1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Posted on Jan 08, 2008
    Novelist:
    Scholar:
  • 136 Answers
You are not getting access b/c the router hasn't assigned you an ip address yet.
make sure you use dhcp on the router to give you an ip address. if you are using wireless with encryption you will need to enter the network key for it to work.
alternatively plug it in the lan cable go to network connections right mouse click select tcp/ip and assign yourself an ip address.
use 192.168.1.100
gateway is 192.168.1.1
dns should be auto matic.
good luck
smeags.
Posted on Dec 31, 2007
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Router shows a strong signal but when i connect i get a message "no internet access"
1. Using a computer that is plugged into the router directly with a network cable, open a web browser.
2. In the "Address Bar" type http://192.168.1.1 and press Enter.
3. A box should appear asking for a "User Name" and a "Password". Leave the "User Name" field empty, and type your WRT54G router password into the "Password" field (the default "Password" is admin) and click the OK button or press [Enter].
4. The WRT54G "Setup" page should now appear. Click onto the Wireless page.
5. When the "Wireless" page loads, you should be on the Basic Wireless Settings sub-section.
6. Look for the "Wireless Channel" option. The default channel is set to "6 - 2.437GHz". Change it to either "1 - 2.412GHz", or "11 - 2.462GHz".
7. Click on the Save Settings button toward the bottom of the page to save changes. Click Continue when prompted to reload the page.
8. The channel of your WRT54G has now been changed. Restart your wireless computers so that they can automatically connect using the new channel.
9. If you still experiencing interference using channels 1, 6, or 11, try switching the router to the other channels as well (2, 3, 4, 5, 7, 8, 9, 10) and find one that captures a good connection.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | Linksys Wireless-G WRT54G Router
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
Nov 01, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G linksys was connected 3 days ago to the laptop and the ps3. two days ago, i couldnt connect to the internet on the ps3, but could on the laptop. Yesterday, i couldn't connect on either one. I've...
First steps (forgive me if you are already doing this). Hook up the laptop with cat5 network cable to port on router to verify you have internet connectvity. Verify router settings that DHCP is on or off. It should be on unless u are using static IP's on network. Go back wireless and see if you can connect. IF yo do, open a DOS prompt and use ping command (c:>ping 192.168.x.x ) where x.x are the ip setting of router. In most cases the router IP will be set to 192.168.1.1 Check the most basic settings. Sometimes it is a simple thing that is throwing everything off. Also consider if your laptop is at the very edge of your signal area. Try moving laptop right next to router.
Hope this helps.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
My linksys wrt54g v8 will not recognize the internet
Try to do a hard reset on the router. Hold down the button on the back of the router for 10 seconds. This will clear all of the settings out of its memory. Then try to connect again. If this doesnt work power down both your router and your cable modem. Let them sit for a minute and then plug in the modem and wait 30 seconds. THen plug in the Wireless router. The issue should resolve itself.
Gary
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Linksys router problem
Try a factory reset on the router, in most cases this can be done by holding the reset button on the unit down for 10 or more seconds. Once this is done you may have to enter any settings into the router again.
Also, try download the latest firmware from http://www.linksys.com and upgrade the firmware on the router.
Dec 08, 2008 | Linksys Wireless-G WRT54G Router
Wireless conectivity
I had the same problem with this model. I was trying everything including resetting the Linksys to a factory default and loading latest firmware, nothing helped. I had to replace the Linksys to fix the problem. I think your radio on the Linksys is not working even you have a signal showing on your laptop.
Regards
May 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
80 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
