JustAnswerhttps://www.justanswer.com > Ford Repair
Mar 15, 2020 - Ok give me a minute to look it up. It is under the lower intake manifold. You have to remove that to replace the knock sensor. The block, you ...
Hi Rusty, There's two links below showing the position of 2005 Ford Explorer Crankshaft Position Sensor and the 2008 ford edge camshaft sensor location. It seems like they're all in the same position, I hope this helps.....CHEERS
.. 2005 Ford Explorer Crankshaft Position Sensor Location
Camshaft Position Sensor
The camshaft position (CMP) sensor detects the position of the camshaft. The CMP sensor identifies when piston No. 1 is on its compression stroke. A signal is then sent to the powertrain control module (PCM) and used for synchronizing the firing of sequential fuel injectors. The Coil On Plug (COP) Ignition applications also use the CMP signal to select the proper ignition coil to fire. The input circuit to the PCM is referred to as the CMP input or circuit.
There are two types of CMP sensors: the three pin connector Hall-effect type sensor (Figure 25) and the two pin connector variable reluctance sensor
and next the location of 2003 ford focus camshafts position sensor
1996 Ford Truck Explorer 4WD 4.0L EFI 6cylthe Camshaft Position Sensor is located:
Under hood, center, rear engine area,mounted on center upper rear of engineblock
It does not have an ignition control module. The PCM (powertrain control module) fires the coil pack based on signal it recieves from the crankshaft position sensor and the camshaft position sensor.
