Question about Western Digital (WD1000VE) 100 GB Hard Drive
Hard drive fall
I have a WD1000VE drive 2,5'' in a portable case.
about a week ago it fell from the desk and since then it does not work.
Windows (XP & Vista) can only see a portable disk but the name is unknown and also the size is zero. Have tried every software recovery known but the dont work because they can't see the HDD. Is it a hardware problem and what can i do to save data?
  • 107 Answers
The portable case has a bus interface that lets any generic disk installed talk to your computer. That is what Windows is seeing. The fact that there is no drive size either means that the drive became unplugged (unplug the cables and re-snug them), or there is non-visible damage to either the interface of case, or on the drive itself.
I would go with the drive is bad. They don't like falling. If you feel reasonably comfortable with a small mod, you could plug it straight into your PC and see if windows detects it. If nesc. unplug your CD drive and use that cable for the test. Make sure you're PC is off before the mod, ground yourself, and don't force the ribbon cable. Good luck!
Cheers,
Posted on Dec 31, 2007
Can I retrieve info,documents etc. from these old bkf. files on my simpletech 160gb usb 2.0 portable drive
The BKF file is only a reference to allow the XP os to know what program opens which file. It doesn't contain photos or music or documents.
Jul 09, 2013 | Computers & Internet
How can i format the expansion drive
@swaroop_2k6
You can let windows format the portable HDD by doing the following:
For XP / Vista / Windows 7
1. Click Start > Computer (My Computer for XP)
2. Right click on the Removable Disk and click Format
3. Put a check on Quick Format and leave the other settings to Default and click Start
Sep 07, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
I bought an ibm usb portable dikette drive by amazone and my xp doesnt recognize it , i have a driver for this and if yes where can i get it
You should not require a driver if you are running windows XP. Does windows ASK for a driver or does it just say that the hardware might not work properly - because in that case it might just be that either the hard drive or the casing that the drives comes in is damaged.
Feb 03, 2011 | IBM USB Portable Diskette Drive (05K9276)...
My simple drive external harddrive now lists itself as Local Disk (F) in my computer folder, and when I try to open it says, F:/ is not accesible the file or directory is corrupt and unreadable. it work a...
If it worked a few days ago then you could restore your system to a week ago and it should recognise again
i see no mention of what oprerating system you are using so I will assume XP.Vista or Windows 7
Using XP then follow these steps
Go to Start
Then All Programes
Then Accessories
Then System Tools
Then System Restore
This will give you a calendar to choose an earlier date
select one and click accept or continue and wait for the machine to shut down and restart
Once restarted a message should appear saying if the restore was completed.
Plug in your drive and test for fuctionality.
Let me know if you need the procedures for Vista or Widows 7 because they are a little more envolved.
All tho the steps are simalar I would much rather give you the correct infomation.
Hope this helps,Cheers Misterdj
Mar 27, 2010 | SimpleTech SimpleDrive Portable USB 2.0...
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
USB External hard drive 160 GB not recognized by desktop Windows XP OS
Very possible your problem is that this drive is not externally powered and your desktop does not put out enough power to drive it.  I'm guessing your desktop is older.  Especially if your desktop is USB 1.0 this problem would occur.  Your best bet in this case is to either mount a newer USB expansion card into your desktop, or get another externally powered harddrive and transfer data over to it from this one with your laptop.
Nov 01, 2008 | Verbatim SmartDisk Firelite Portable USB...
External USB drive making clicking noise - Windows does not recognize it!
The drive is damadged bad. youll have to go to a data recovery centre, but that can cost $700+ if you really want your data back.
Sep 19, 2008 | Western Digital (WD1000VE) 100 GB Hard...
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
WD1000VE external hard drive not recognized
If possible check it out on another computer.
This will then establish one or the other which is misbehaving.
Then come back
Feb 11, 2008 | Western Digital (WD1000VE) 100 GB Hard...
Western Digital (WD1000VE) 100 GB Hard Drive Logo
106 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
