hi i hav bought new acer aspire series 4520 amd x2 i gb ram and running on windows xp sp2 even after installing the device drivers for blue tooth it said there is no blue tooth device
hi, check if your device is enabled, you can do this by --- right click my computer..-> properties--> hardware tab--> device manager --> right click on the blue tooth icon and clcik properties. --> check if enabled..
if it is enabled check if bluetooth is enabled at startup { type msconfig in RUN in start menu, click startup tab..check if it is enbaled in startup}... or else you have to manually switch on bluetooth each time u intend to use... hope it helps.
my ethernet controller driver wasnt installed i cant use a wifi connection and even in wired lan...
(More)
my ethernet controller driver wasnt installed i cant use a wifi connection and even in wired lan connection i've lost the cd driver installer pls help me...
