Question about Intel Desktop Board D845WN Motherboard
Cannot power on PSU
I have checking my mother board, there is supply power in, but when i press the on/off button, mother board not working, it is standby battery (CR2032 3V) low will cause unable trigger the PSU power.
  • 1 more comment
  • john2008 Jan 01, 2008
    Already changing new PSU, but still unabled switching on the PSU. i have checked the wires connection (HDD led, reset sw, power sw, power led) to motherboard, even i press the button but still cannot see power led light on.
  • john2008 Jan 03, 2008
    The PSU had a main incoming power supply and out going voltages supply to motherboard, and beside the power connected at motherboard LED (green) is ligh ON, but when i trying press front panel power switch on/off, there is no LED light ON or power trigger the PSU and motherboard.
  • peculiarguy May 16, 2009
    I too have the same problem with my mother board. i.e., the power supply is ok. standby LED (Green LED on the mother board) is glowing when power on. but when i press the power button in the front panel, the computer doesn't start. (my mother board is ASUS K8S-MX, Processor is AMD Athlon 3000 64 bit). Someone help me please
    Scholar:
  • 131 Answers
Does you cpu fan runs
Posted on Jan 02, 2008
  • 4 more comments
  • M Karthikeyan
    M Karthikeyan Jan 02, 2008
    What do u mean by PSU is it the SMPS of the CPU
  • M Karthikeyan
    M Karthikeyan Jan 03, 2008
    If the problem has not been solved yet Kindly give me your current status. I will be glad to help you.
  • M Karthikeyan
    SMPS means Switch Mode Power Supply. Its the Power supply Unit for the CPU. Kindly Post me your Current Status, I will do my Best in Helping You.
  • M Karthikeyan
    M Karthikeyan Jan 04, 2008
    The processor might not be seated correctly, Remove the processor from the slot, and refix it properly and carefully. Press the power button and check it.
    Another way is to deassembly the cpu. Take the MB, power supply unit, ram, keyboard, and monitor.
    spread a non conductive protection on a flat surface, place the motherboard, SMPS unit, ram, keyboard, monitor, Now connect the barbones to the mb. Now switch on the power and check if it powers up.
  • M Karthikeyan
    M Karthikeyan Jan 05, 2008
    Kindly POST me your status.
  • M Karthikeyan
    Check your system with a good working processor just like yours. if the system works, the problem is with your processor, otherwise the problem is with your motherboard.
    Kindly POST back with your results
    Genius:
  • 1,601 Answers
If you know for certain that the Power Supply is good. (tried another in there) then you have a bad motherboard. No, the CMOS battery will not keep it from coming on.
Posted on Dec 31, 2007
  • 2 more comments
  • Thomas Christopher
    Thomas Christopher Jan 01, 2008
    does this really deserve a inappropriate?
    This does answer your question,
    Did you try changing the battery? Did it help?
    Try disconnecting some of the extras and or unnecessary devices that are or would pull power (fans)
    Also anything not needed to power the system.
    Bare bones boot boot configuration
    If these do not work then it is safe to say that the board is bad.
    Thomas Christopher Jan 03, 2008
    It is safe to say that the board is bad.
    Thomas Christopher Jan 04, 2008
    I helped you figure out your problem. Please rerate this to at least "thanks for trying"
Computer wont turn on
Is the fan running in the power supply ?
Unplug all the drive power leads and try it.
If it still shuts down, try another PSU, by just plugging it onto the mother board only. If it still shuts down, I suggest it is a motherboard fault. The motherboard turns on the PSU, when you press the on button, it shorts 2 pins on the motherboard to start the power.
Mar 27, 2013 | Computers & Internet
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
My computer won't turn on. I cleaned the Air spinner thing, checked the mother board, and everything was fine. The computer is an Emachines T2824. Can i have some assistance on how to get it to turn on?
If the machine is doing nothing at all when you press the power button, chances are your Power Supply Unit (PSU) has failed. If this is the case, the only way to fix it, is to get a new PSU.
Nov 03, 2010 | Computers & Internet
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Powers up shuts down in about 5 seconds
hi! if that's the problem inirially chech your power supply unit(PSU)
you can't enter in any of those system unless you stabilise your power,it's kind of tripping off.can you check your PSU,doing this is work by qualified technician,if your qualify follow this procedure unplug your PC on avr (auto variable regulator power )supply ,disconnect all power supply on mother board and to accessories take the big one with several connection.get piece of wire or paper clip w/o insulation insert to two terminal on one black terminal,the other on green terminal, plug it on and switch on observe if will trip of checking on blower fan backside of PSU. if trip off replace your power supply or if you have other PSU put it on to your PC satrt in on.If symtom persist you problem on memmory card or video card.Three of this part can run your w/o hardis and cd-room.you can check your bios,cmos set up press delete or F2 at start of windows sart up.
Mar 18, 2009 | Dell OptiPlex GX270 PC Desktop
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
Computer will not boot
Option 1 :
Remove completely the mother board from Cabitnet.
Try to check it on other Cabinet.
Option 2
Remove mother board and re- plug the SMPS power Connecter to Mother board outside of cabit and make sure that motherboard is not touching directly to Metal part of cabinnet.
then switch on computer and check
Nov 22, 2008 | ASUS P4S800-MX Motherboard
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
Intel Desktop Board D845WN Motherboard Logo
137 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
