Question about Toshiba Televison & Video
Flashing green light
I have a Toshiba 52JM9UA just shut itself down. Red power light is on but green light is blinking intermitently about half a second apart then it tuns off. After about 5 seconds the sequence repeats and sounds like its trying to turn itself back on. Blinking green light then off again. Followed trouble shooting guide nothing worked can you advise. Unit is not even 1 year old.
  • Bahainfo Apr 19, 2009
    I have the same problem, any suggestions?
Sounds like the bulb is blown. Its the main lamp in the side of the set. you will see a small door there once you take it off there is 2 screws to remove and bulb in its casing will slip out. by looking at the buld you should be able to see if its blown. You should get approx 3000 to 4000 hours from a bulb but if you are a heavy user of this tv with higher contrast the bulbs dont last. i have this model tv myself and ive been told that they are not designed to be run for long periods of time and dont use gaming machines on them. Shame they dont tell us this when we are buying them.. hope this helps you Craig (crazy@woosh.co.nz) let me know how you get on
Posted on Feb 25, 2008
Hi I have the same problem with my tv.. how do i fix this?
Posted on Jan 04, 2008
Hi! I have the same problem with my TV and i'm in Brazil (S. America) and here we havent this part. How do i fix this?
Posted on Aug 07, 2008
Had a tech look at the problem and said that the light bulb had totaly blown itself. I thought it would be 3 bulbs but it was just one and had a colour wheel inside. The service cost me $400.00NZ dollars. the bulb I would guess would be around the $200.00 dollar range. Next time I know what to look out for.
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
My Philips plasma only shows half the screen. The other half is just blacked out.
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
Sep 14, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Sony Trinitron KV-28LS36U no sound or picture, the standby light flashing green and red but if i switch it on a little bit of sound comes and then switches off. how can i repair?
The unit is shutting itself down because a problem was detected internally. When this happens, the standby light should blink a repeated pattern. Please count the number of blinks and post the number here. That will indicate the circuit in which the problem occurred.
Thanks,
Dan
May 19, 2009 | Sony Televison & Video
Immediately Shuts off with blinking light codes
I suggest doing a google search using the tv model # and brand.
I have learned myself that different big screen tvs seem to each have their own common problems. I have read before of power supply issues that cause what your describing.
Mar 11, 2009 | Samsung HL-R5078W 50" HDTV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Powers on shuts off after 10 seconds- red/green flash
its probably the bulb. if the red and gren lights are flashing simultaneously, than that means the bulb is burnt amd you need to order a new one and replace it.
hope this helps
Sep 22, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
435 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
