Question about Whirlpool LSR6334LQ Top Load Washer
Does not spin
The loader does not spin Wife called me in from the garage, washer will fill, but will not spin. She said it had gone out of balance, so she inserted a clothes pin for the lid-switch to see where she could adjust the load, afterwhich it stopped working. The switch seemed to not be actuating after that. How is that switch tied into the whole spinning and balance thing for the washer?
  • 3 more comments
  • Anonymous Feb 13, 2008
    washer wont spin lid swith macking buzzing sound can depress lid switch up and down can mack it work sometimes
  • curtisrchrds Aug 01, 2008
    washer will fill with water, but will not agitat or go into spin cycle. water will drain as usual, but no spin cycle.
  • Sharon Harmeyer Nov 30, 2008
    I have a Whirpool heavy duty super capacity plus washer model #LSR7233DQO and it will not agitate or spin, I do not remember how old it is and am wondering if it would be worth fixing or if I should replace it.
  • gandolf823 Jan 20, 2009
    washing machine hums and fills up with water.will not agitate. agitator will not turn by hand either
  • f1993 Apr 04, 2009
    I HAVE A WHIRLPOOL WASHER MODEL LSR6334LQ1 THAT WHEN YOU PUT A LOAD OF CLOTHS IN IT GOES THROUGH THE CYCLES IT PUMPS THE WATER OUT BUT IT WILL NOT SPIN OUT UNTIL YOU LIFT THE LID IT MAKES A CLICK THEN YOU PUT THE LID DOWN AND IT WILL SPIN OUT AND FINISH THE LOAD. I LOVE MY WHIRLPOOL, PLEASE HELP!!!!!!!!
I have a Whirlpool Super Capacity Plus, top loading, washing machine Model LSR7233EQ0, Serial Number CF4654304.
The machine fills and drains, but will not spin out the water.
How do I fix this?
Posted on Nov 05, 2008
  • 51 Answers
The close pin most likely broke the switch. Unplug the washer, remove the screws that hold the top and flip it back and remove the cabinet. with the cabinet off it is easy to replace the lid switch. Cost should be $20. to $30.
God Bless and Happy New Year.
Posted on Dec 31, 2007
Makes clicking noise spin cycle
it may be any part of the balance mechanism under the machine..remember if you did not balance (level) it prior to installing, it has to self level on its own..this usually calls for some noise in the linkages when spinning..
Mar 04, 2014 | Maytag MAT15MNAWW Top Load Washer
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Washer is not ringing all the water out of the clothes and the display reads sd
Don't worry your washer is not the only one.Are you using a HE detergant,and bleach.first remove clothes am sorry there wet,my wife has gone through this problem,if the door don't open push the start button a few time you should hear the pump trying to drain,have a flashlite in hand and is the water going down?
when it starts to spin the water has droped to a point wear it starts to spin.After the spin cycle bleach machine or sanitize, also if it having a hard time to balance to stsrt spinning.I have seen it go 23min. till the water got out of one of the clothes to balance and start spinning ,these machines are very sinsible its what we payed for a washer with a brain.
Jul 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Jul 24, 2009 | Washing Machines
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer was jumping and banging like out of balance and i shut it off when i put it on drain and spin cycle it fill with water
Let it go thru a cycle. If it is a front loader, use full loads. Light loads don't spread around enough to balance.
May 04, 2009 | Washing Machines
Walking during the spin cycle
Try placing it on a rubber mat or carpet that has a rubber backing. The floor may be too smooth and allows it to walk.
Oct 12, 2007 | GE WSXH208A Front Load Washer
Whirlpool LSR6334LQ Top Load Washer Logo
519 people viewed this question
Dan Webster
Dan Webster
Sal De
