I have reviewed your problem with the Whirlpool GU2300 Dishwasher and have the fallowing suggestions for you.
First, unplug the power to the unit and let it sit for a few minutes. This will clear all internal error messages and reset the unit.
You may need to wait up to 3 minutes.
Plug in the unit power and allow unit to re-initialize.
Try to run a normal cycle and time from start to finish. If the unit stops for longer than 45 seconds during a cycle, you may need to have timer replaced.
Hope this reset works for you and you do not need to have unit serviced.
Please rate.....
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Door is firmly latched, I've had the panel off and all connections seem to be tight. This problem came on suddenly.
I started the cycle at about 8am. It is still running now at 3pm.
