Question about Panasonic SC-AK78 CD Shelf System
Trouble please help me on f61 shuts down my
  • 2 more comments
  • allans Jan 02, 2008
    dollar suckers!!!
  • Anonymous Feb 12, 2008
  • sunkissed20 Apr 12, 2008
    My stereo turned off about 3 days ago, and when I hit the power button it won't turn on, it just displays F61. Do I just have the fan replaced and it will work? Is that expensive?
  • Anonymous Mar 24, 2014
    power light is on but wont turn on
I had to replace the fan on my unit. Now it works like new.
Posted on Mar 21, 2008
F61 ON SA-AK78
You may have the same problem as I had..broken solder joints on power amp board..namely the power relay.
Nov 08, 2011 | Panasonic SC-AK78 CD Shelf System
Hello i have a panasonic SA-AK78 and show F61 and don't turnd on.
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Jul 13, 2011 | Panasonic SC-AK78 CD Shelf System
The song is playing and running suddenly the song stops and the error msg when i restart my dvd. The error msg is F61 displays in Dvd's display. Please give a rply.
Hi ahamedfaisal,
Does F61 appear after a minute of playing or shuts down immediately after you power on the unit?
Mar 16, 2011 | Panasonic Audio Players & Recorders
My panasonic sa ht930 volume when you give me presents on the screen and I f6 1 off
F61 is an error code.
It will automatically shuts down your unit.
This is very common on your unit.
Try to checked if the fan is working or not.
I have repaired some unit before, this is the caused why f61 appeared.
The symptom is shutting down the unit after a few minute.
If the fan is not working it will shuts off automatically to avoid further damaged to your output I.C. from overheating.
If confirmed that the fan is working then I've suspect that your output I.C. is shorted.
This is quit technical and need to send to repair shop to isolate the faulty parts.
The output IC of your unit is RSN series and quite expensive.
Pls rate my help.
Thaks for using fixya...
Jan 18, 2011 | Panasonic sa-ht930 Home Theater Audio...
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
May 05, 2008 | Panasonic Home Theater System System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
Panasonic SC-AK78 CD Shelf System Logo
370 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
