Acer AL1916W 19" LCD Monitor
Problem for Acer AL1916W 19" LCD Monitor
I recently purchased and installed the P191W
By timwitted on Oct 24, 2009
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running XP, with an Intel Pentium III processor, 996 mHz, 512 MB of RAM. Thanks,
Tim Weiss
Comments:
Oct 24, 2009
- Thanks, but I don't have 1440x900. And there is no monitor.ini file. The only thing on the disk other than pdf user manuals, is a software called "eDisplay Management" but when I install that, it doesn't run. I always get an error message when it tries to open. Any other suggestions? I found an article that says you can set a user defined screen resolution, but doesn't say how to do that: http://www.brighthub.com/computing/hardware/articles/45962.aspx
Solution #1
posted on Oct 24, 2009
Somewhat Helpful)
MalKontent68
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 176 votes
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Was this helpful?
Yes
No
Popular Solutions for Acer AL1916W 19" LCD Monitor
Questions and Unsolved Problems for Acer AL1916W 19" LCD Monitor
Do you recommend Acer AL1916W 19" LCD Monitor?
Answer
Answer
The lines are wide and not solid, but snowy looking. They scroll at an even rate, which I suppose... (More)
Answer
monter is blinking when ever i start my pc and often while working....
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Sedona, AZ
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
