I strongly aggree with the Vacwater, He is right in his observation that minerals like calcium and salt cannot be completely removed in an ordinary 5 micron filters. Fine residues of these minerals passes thru the filters. However, complete removal can only be achieved in a Multipass Reverse Osmosis systems. But under your filter system, it will of course minimize the minerals present in your water supply, but not remove it. That's why you still have the white deposits in your kettle. But without your filter, the situation
will be worst.
5 micron filters are used most in filter systems to remove sand, silt and sediment, but it will not take our calcium or salts. That is causing the white build up in your kettle. Only Reverse Osmosis filtering can take out the white build up.
I don't believe that any filtration system is capable of removing dissolved calcium from water and that is what causes the white deposits. Water softeners will, but I don't like the idea of dissolved salts in our tap water.
