Question about Oster 5838 ExpressBake Bread Maker
Breadmaker Won't Knead
I'm trying to bake bread for the first time with a new breadmaker. The kneading cycle won't turn on. Everything seems to be set up correctly. Any suggestions?I'm using the French cycle.
  • 25 Answers
SOURCE: West Bend breadmaker 41030 needs knead bar
try here maybe measure your part then maybe a sub will work if someone can send you the specs.
Posted on Jul 24, 2008
  • 25 Answers
try here to see if you can match it
  • 204 Answers
SOURCE: missing part - regal breadmaker They have manuals and parts for most breadmakers at very reasonable prices.
Posted on Jan 13, 2009
  • 3433 Answers
SOURCE: Oster Breadmaker -keeps kneading, even during/after baking
What does it knead? An unstuck switch? Ok, give me the bread, I'll hold it till things get better.
Alright. Does theswitch move or is it stuck? I told you that wasn't a mini scale. Are you capable of dis assembling it? Ok, you aren't. Go to a parts store (auto parts) and pick up a spray can of crc electrical cleaner. Then rush home safely and using the straw on the spray, Spray that evil button and work it while doing so until you hear or feel it snapping again. tilt the machine over the sink and let any excess cleaner run out of the machine. Now, this cleaner is flammable so no smoking or cooking going on. This cleaner is also fast drying and any liquid will evaporate and make a huge hole in the ozone layer and you can watch the falling stars while you sit enjoying you unshared bread. :) This cleaner should free up the switch. Do the spraying and draining out doors for fume sake. You may need to lean the machine side to sideas you work the button. Let the machine dry out before plugging it in. About half hour should do it if you have got all the excess liquid out. When you are ready put the switch in the off position and plug it in. If this doesn't correct the problem the switch needs replacing.. If the machine appears to be working right. turn the switch of and on several times until you are ok with its functioning.. Wipe dow the machine to remove any residue left by the cleaner.
Ok, serious now. the cleaner will vcompletely dry up but it may smell for a little bit. If his worked , all yhis one finger typing was not in vain. Good Luck, -Ned_
Posted on Sep 17, 2009
  • 1280 Answers
SOURCE: I have a toastmaster Bread
Unless the sound is mechanical like metal on metal etc. what you may be hearing is the sound of the dough ball being knocked around and kneaded. Sometimes that gets pretty loud. While it is kneading go ahead and open the top and see if you think the dough ball is making the noise. If it seems to be coming from somwhere else then you may have a more serious problem. Is this a new noise or it this the first time you have used the machine?
Posted on Nov 08, 2010
Testimonial: "its definately mechanical..."
Kneading paddle bakes into the bread
Kneading paddle on EVERY breadmaker usually bakes into bread. Let the loaf cool and then gently remove it. Or use the dough setting and cook bread in the oven. (i do this) delicious!
Jul 05, 2017 | The Kitchen Appliances - Others
How long should bread knead in the machine
Depends on the texture you are looking for. Typically a machine has a pre-set program that kneads a certain time and shuts off. If you are using a recipe that is a bread that you make by hand, you could use the machine to knead the bread and rise the first time, then punch it down, knead by hand and form a loaf and bake in oven.
Oct 17, 2014 | Kitchen Appliances - Others
Everything seems to be normal but the machine wont knead the dough
If your machine making a sound as if the elecric motor is humming or is it completely quiet?
Mar 13, 2013 | Panasonic SD-YD250 Bread Maker
In west bend do you have to use the dough cycle first
Dough cycle is for just mixing and kneading the dough. Like if you want to make pizza or buns. It will only mix the ingredients, cycle for a while to knead, then it's finished. It won't bake form there. Any other cycle will make the bread.
Jan 09, 2012 | West Bend Kitchen Appliances - Others
Bread machine model TR520, mixes the dough, stops for a long time, then starts mixing the dough again continuously without starting the bake cycle. This was on the french program. The machine is new...
By continuously do you mean forever, non-stop kneading? I'm guessing not. French bread is really nothing more than white bread dough kneaded for an extra long time. The extra kneading creates the chewyness common to French breads.
Hope this helps!
Jun 17, 2011 | Breadman TR520 Bread Maker
Paddle sticking in bread when baked bread is removed. Oster Breadmaker 5838
This is a common problem. The solution is to take the paddle out of the machine after the last kneading cycle and before final rise/bake. You may want to take the pan out of the machine to remove the paddle to be safe...unless your machine has a pause cycle. Hank
May 18, 2010 | Oster 5838 ExpressBake Bread Maker
Kneading blade cooks into the loaf
Hi Jessica,
As I read the manual, under the Care & Cleaning section,
"2. If the kneading blades remain in the bread pan, grip the kneading blade and
pull straight up to remove......"
Based on the diagrams and instructions, I don't think you're supposed to pull the blades before baking...why do you want them out? Cosmetics?
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using,
Jan 08, 2009 | Black & Decker B2300 Bread Machine
Bread is overly dry and coarse textured
You're doing everything great with your ingredients. Listen to your machine or watch it. Stop it before the bread is in the rise cycle and restart it after the kneading cycle.Try running the knead cycle two times, then the rest of the baking cycle. If the bread is still too hard try using the kneading cycle three times. This process is trial and error, but I firmly believe this will solve your problem as it did mine.
Dec 10, 2008 | Sunbeam 5891 Bread Maker
Kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Dec 05, 2008 | Sunbeam 5891 Bread Maker
Oster 5838 ExpressBake Bread Maker Logo
182 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
