Hi, It was better if you have specified the brand of the cd drive. However the following would fix your problem.
1. If you have noticed earlier , check for a small hole ( the size of a pin ) on the front of the cd drive just below the tray which opens. depending upon the brand of the cd the whole might be located anywhere ( below or above, right or left corner ).
2. Having located the hole. Get yourself a Pin or a Safety Pin or a copper wire. Insert the pin or the wire inside the hole which will release the clamp inside and now manually try to pull the Cd drive with your finger nails..
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend...
(More)
Please suggest the best external hard drive 320GB.. Which one should I prefer? Seagate or transcend ?
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
recently installed binatone S1545 onto computer running xp home. works well but unable to stream...
(More)
recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your sound card unable to play''
