Question about Audio Technica Headsets
Hedphone problem got the headphons and i 've lost the jack .how much will you charge me.I can
0 characters
1 Points
No sound from my sennheiser 840s
Hi Suzanne, I want to help you with your question, but I need more information from you.
If you step back and look at this problem, there are two to three things that immediately come to mind: 1) have you hooked your headphone input to an output of another device like an amplifier or tv or ...? 2) Are you certain that the headphones are charged and the power to the base station is good 3) pairing the headphones to the base may be an issue.
Please clarify some things and anything else you can think of. Chad
Dec 27, 2014 | Sennheiser Set 840s Rf Tv Amplifying...
Connecting headphone system to a dvd recorder
does dvd record have head phoen jack out if not use rca outs in back rca to sterio mini jack to headphone wirless base ok
Jan 11, 2008 | Headsets
How do I pair my phone to my radio?
Hi, if you say "your phone", I presume you mean your headphone. If that is so then there should be a headphone socket or jack if you wish, somewhere in the front or at the back of the radio. It will have a small headphone symbol above or below the socket, or even the word HEADPHONES underneath or above.If your radio (Being a CD player as well) has a flip- open cover in the front, then the socket will be in the corner " left or right" behind that cover. If I have misunderstood your inadequate description, then your cellphone could be plugged into the line in RCA socket at the back of your radio (some also in the front) or stereo jack in, using a cable with a jack plug on one end and RCA or stereo plugs on the other end.
Hope this will help
Have a good day.
Sep 09, 2014 | Headsets
Nakamichi wireless headphone nw6000 beeps every 5 sec while using in wirelss mode. but when used with a direct audio jack it works fine.
battery is flat and will not re-charge, pries apart headband from body, locate two tiny screws holding battery in and remove by sliding
change battery and allow to charge on base for a full 24 hours
May 22, 2014 | GN Netcom GN 9120 Professional Headset
I have 2 plugs on my Logitech ClearChat Stereo Headset Headset I have a table top computer where do I pug them
The headphone plug goes into the green jack on the computer. The mic plug goes into the red jack on the computer. The headphone plug with have three segments on the jack, the mic plug will have two, and they'll both be marked. If you're computer doesn't have color jacks, the mic will go into the one with a picture of a mic, the headphones will go into the one with a picture of a headphone or speaker.
Jul 07, 2011 | Logitech ClearChat Stereo Headset Headset
How do i connect the Microsoft LX-3000 Lifechat headphon to x box
how do i connect the Microsoft LX-3000 Lifechat headphone to x box 360, i plugged the usb into the front of the x-box and its not working , i,ve got no drivers, but i can down load them , but what do i do with the drivers then?
Apr 16, 2009 | Microsoft LifeChatâ„¢ LX-3000 Headset
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Insignia Bluetooh Headphone won't turn on. but can charge
Well i fix it putting on power and pressing both volume buttons for 15 seconds. Then he turned on with no problems
Mar 22, 2009 | Insignia Bluetooth Wireless Headphones...
RS 130 not working?
I am having the same problem...i tried resetting it as luck
Jan 13, 2008 | Sennheiser RS130 Headset
Headsets Logo
13 people viewed this question
Top Audio Technica Headsets Experts
Brian Sullivan
Brian Sullivan
Are you an Audio Technica Headset Expert? Answer questions, earn points and help others
