Question about RCA HD50LPW42 50" Rear Projection HDTV
Sawing noise I've had this tv for about 2 years. Turned it on yesterday - went on but there was a sound I never heard before - like a table saw (not the whinning noise that happens when the lamp needs to be replaced). There was a picture. Turned it off, then on but this time no picture and the power light did it's blinking thing (like it does when it's not able to communicate with bulb). I was sure it wasn't the bulb because we just replaced it about a year ago, but I had new one which I switched with the current bulb, but the results were the same. It's not a bulb problem. What else could it be?
  • mogall Dec 31, 2007
    Thanks HandyBoy. What is the ballast? Is it something I can replace on my own?
  • Anonymous Feb 07, 2008
    RCA HD50LPW164
    I have the same problem after 2 1/2 years. There is a loud whirling noise and the color fades in out of different shades (purple, blue, yellow). The very loud noise continues up to 20 minutes after you shut off the TV. The noise first came 3 months ago and stopped, then it resurfaced.
    Did any one find out what the problem was?
  • 3 Answers
Sounds like it is your color wheel.
Posted on Dec 19, 2008
    Problem Solver:
  • 18 Answers
Sounds like the same problem I encountered with my TV might be
ballast.
Posted on Dec 31, 2007
  • Handy Boy Jan 05, 2008
    looks like your on the handy side, please double check that your bulb is still intact. I know your sure its still good but it pays to check. The ballast needs to be done by a tech as much as I would like you to save money on it. It sometimes pays to have fall back, the tech will give you a warranty on the job. Good news is the ballast is not that expensive depending on the model that you have. If you look at the manual that came with your tv it should say on the trouble shooting guide what the trouble is. Two red blinks indicates colour wheel. Three red blinks and one green is the bulb etc. those were just samples of course and not to be taken literally please always refer to your manual.
10" Contractor's Saw II - Model 36-640
Pull the saw apart and inspect the parts, something is broken that is for sure, only a through inspection will reveal the cause, it is a never before heard problem.
Sep 07, 2016 | Delta Saws
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
Bosch table saw GTS1031 won't start.
In case of this kind of questions you can only advise someone to go back immediately where they have bought the tool for warranty or exchange or money back.
No other suggestions but few years to late to give the only right answer in this cause of question.
Aug 29, 2014 | Bosch GTS1031 10-in Portable Jobsite Table...
I haven`t used the saw in a year, should I lubricate the motor bearings? Something is making a sqweaky sound when I turn on the saw.
Unplug the saw. Look inside the blade housing for any foreighn objects. if it is clear, shoot some oil into the bearings and work it in well.
Feb 25, 2011 | Ace Hardware Ace; Table Saw with Stand
I was cutting 2" dense foam insulation board,
The problem you have is a faulty field coil, the Bosch saws unfortunatly have a bit of an issue with this. The coil can be replaced separatly so you won't have to replace the whole motor. Bosch has a 1 yr warranty on thier table saw so this is a warranty replacment provided the saw was purchased within the year. If not the coil replacment is still cheaper than buying a whole new saw, but should really be done by a service center because of the level of difficulty of the repair.
Nov 10, 2010 | Bosch 4100 10" Worksite Table Saw
I have a craftsman radial arm saw 113.23100 which has not been used for possibly 20 years. I cannot get the motor to rotate in order to make 45% angle beveled cuts. I have turned the bevel lock knob to the...
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Jun 27, 2010 | Skil 10" Table Saw
I am borrowing my brothers Craftsman model 137.218240 table saw. Unfortunately, it has a on/off switch problem (I believe). Yesterday, I was able to use it all day although, at first, I had difficulty...
You can chec wiring or switch with an ohmmeter to determine if it is bad. You should be able to remove a few screws to access the inside of the saw fairly easily. You can easily by-pass the switch by twisting the wires together. Though it will have to be untwisted to shut off again. You could just unplug it. There isn't much to these.
Oct 12, 2009 | Craftsman 10" Table Saw
My table saw will turn on, but sounds very loud
Possibly bearing wear, or the blade rubbing against the guard/housing. Unplug the saw and spin the blade slowly by hand, if it feels notchy then I would suggest bearing wear. if it only seems to feel notchy in places then it could also be damaged gears.
Oct 24, 2008 | Saws
RCA HD50LPW42 50" Rear Projection HDTV Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
