Question about Kodak EasyShare One Digital Camera
Problem putting card and transfers
Keeps telling me Drive not ready for use door may be open, check drive\divice\harddisk1\DR3 and make sure that a disk is inserted and that the drive door is closed.. I have to constantly hit continue about 150 times to get pictures to load up and then to remove them from the divice the same. Can you help?
  • 1 more comment
  • tonkadiesl Dec 31, 2007
    Never had a problem till I got a new camera and downloaded the new 6.4 version..Used it for a year before now..
    I have another card and will try it..
    When I got the new camera I bought another card just to have. The other card did the same thing.
    President:
  • 1,944 Answers
I have seen this numerous times in the past occuring in Sony/Canon/Minolta/Olympus digital cameras. Almost on all occasions the problem was with the memory card, either it becoming corrupt or simply malfunctioning. What I suggest you try, is to back up everything on the card with an external card reader and format the card. After formatting, let the camera format the card again. If the problem persists, you will need a new card. The problem may lie with a malfunction of the card slot of the camera but this is not usually the case unless it has been physically damaged or moisture has gotten in.
Posted on Dec 31, 2007
    Sergeant:
    Champion:
  • 347 Answers
Hi tonkadest, when did you started having this problem?
make sure you have the software to transfere photos installed.
  • Santiago Vallejo
    Santiago Vallejo Dec 31, 2007
    tonkadiesl, Here you can try to correct the problem yourself, its very easy to use, and helpfull, go there, and let me know if you still have the problem.
Iam recieving thia message when i attempt to open a file with gimp 2.8 "There is no disk in the drive. Please insert a disk into drive \Device\Harddisk1\DR1"
I had the same issue, due to opening a file from a SSD card previously, which was no longer in the PC. Clearing my recent documents history fixed it. HTH!
Nov 11, 2013 | GIMP Computers & Internet
I want to put info from my Flash Drive to my e-mail to send a resume.
first insert flash on to computer go to divice manager select the usb port u put the flash in , open contents then start your email under compose message select attach it will ask you from where select flash and select resume it will transfer data to email.
Jun 25, 2012 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Jul 20, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
How do i get pics off computer to pandigital frame..keeps telling me to insert media card- do i have to really transfer to a flash drive to put on frame
Hi friend,
You need to purchase media card reader then you can transfer your photo. media card reader is device which is use as cable connect to computer ..t
Dec 20, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Format and Check SD card
Purchase an inexpensive card reader such as the Ativa, available at Staples and Office Depot for $9.95. Put your memory card with the photos on it into the reader and plug it into a USB port on your computer. Windows will recognize it as another drive and assign it a drive letter. Using any graphics program, or Windows Explorer, navigate to that drive, open the file containing the pics, click select all, and copy the pics to a file on your computer. Make sure that all the pics have transferred or copied to the new file. Replace the card back into your camera and format the card so it is empty and ready to receive new pics. FYI: Less than 1 gig memory cards are available on ebay for dirt prices. Also, go to the camera manufacturers website and see if they have a firmware update for your camera that allows larger than 1 gig cards to be used. I had to do that for my Fuji S700 so I could use 4 gig cards. It used to max out at 2 gigs. If this has solved your problem please rate it accordingly. Good luck.
Jul 05, 2009 | Samsung Digimax S800 Digital Camera
Bluetooth
Are you sure you have bluetooth! Toshiba use the same hard drive image for the whole range of a certain model that is why you may have the software but not the hardware, have a look in device manager and see if you have a bluetooth device installed.
May 31, 2009 | Toshiba Satellite P305D-S8818 Notebook
Can't reformat my memory card
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 25, 2008 | HP Photosmart M425 Digital Camera
    Lacie 250 gb gives error while accessing some folders
    I took mine to a place to get it fixed and they said it was beyond repair and the only option is to recover the data and transfer it onto another disk
    Jan 18, 2008 | LaCie (300728U) 250 GB Hard Drive
    Problem downloading off of camera card
    Its Because Quicktime tray program having malfunction.
    You can try few methods here is the method that I got from Apple
    1. Open QuickTime Player.
    2. From the File menu, choose Open Recent, then choose Clear Menu.
    Also you can disable Quicktime update
    I explained the most possible fact. If issue persist please inform with new post.
    Good Luck Happy New Year
    Dec 31, 2007 | Kodak EasyShare One Digital Camera
    Chamberlain Whisper Belt Drive
    door does not close without holding wall button in
    Oct 15, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
    Kodak EasyShare One Digital Camera Logo
    27 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
