Question about Samsung (SP0822N) 80 GB Hard Drive
A fire shock in the back plate region
What can be the it repairable? after using a diode the system is detecting the hdd but it's impossible to format fdisk or do anything with it.plz help me.
  • santydada Dec 31, 2007
    please reply can i find the burnt part from any where or can someone send me the plate shown in the figure, i promise to pay the price for it if it works. I m from Nepal so Indian friends can easily help me out if the want.
  • 75 Answers
Diode is just pass the power supply to ckt assembly ,so it detev=cted by system,but the reason of burning may main chip or some thing other chips are got dead,so u cant service the board if u are not expert in servicing,your work is just trail and error method,dont do that
just go to samsung website and ocate your region and contact them or search for local other technition ,
best solution is (for meadium expert) change the ckt assembly and try to recovery
Posted on Mar 06, 2008
No boot hd disk error
HDD not Detecting only Some region, if you HDD data cable damage, HDD power Cable damage, HDD port damage, or HDD bad sector. But normally you change HDD data or power cable or mother board port. And i suggest mother board all connection disconnect and only HDD connect and open bios and search your HDD detected.
More Technical Help TechSupportMart
Feb 05, 2014 | Seagate Barracuda 7200.7 40 GB Hard Drive
Cant detect my hardisk
this could be anything shorted diode in hdd main board.or faulty sata controller or missing voltage.could you describe the laptop? brand model etc
Mar 20, 2013 | Computers & Internet
No operating system found
check the bios setup for hdd detection if hdd detected in bios then reinstall or repair your OS
if hdd not detected by bios setup then you have to open hdd cover
you will find a fpc cable betwen hdd & mother board
just open the connector carefully & refit & apply a small tape pice on the connector lock after reinsert the cable
Feb 19, 2011 | Samsung X05 Notebook
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
Oct 03, 2010 | Computers & Internet
Humming noise and does not heat and burning smell
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, for safety reasons, to avoid a fire or explosion, shuts down the system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace.
Jul 17, 2010 | Sharp R-1490 Microwave Oven
1993 ford explorer
If you have fuel, replace the coil plate, you fried the diode in the coil plate causing it to not fire to test you need a spark plug detector light to see if your getting spark. If you just disconnect the wire and test it like the old spark plug system you will fry the coil or the diode in the plate, I forget what ford calls it, GM calls it a firing diode?? I think rusty memory.
Jun 01, 2009 | 1993 Ford Explorer Limited
Unable to login in my computer
try setting your bios to defaults when you get in that bios screen.make sure to save it and then may also need to reinstall windows os .vista or xp etc.
Mar 04, 2009 | HP Hewlett Packard Smart Buy- dc5750...
System can detect Fujitsu MHY2160BH : 160GB HDD, but cant install
it seems that your computer might have a SATA hard drive which could not be detectable by windows xp, try to install vista it will detect it easily.
otherwise use dm (disk manager) for detection and partition.
Dec 17, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
Multi region hacks
Try this may be work
Put DVD into player - wait for regional code violation screen to appear
Once this has occurred press the M (Memory) button on your remote
Press 1 for Title 1 and Play on the remote - this will over-ride the regional code violation detection menu
You can watch the movie by pressing Fwd on remote and change chapters by using the T (Title/Chapter) button on the remote)
Switch On DVD player without disc in machine
Press Enter
Press 8, 4, 2, 6 and 9
Press Enter
Player should turn itself Off. If not switch it Off
Switch player back On
Mar 05, 2008 | Televison & Video
Keyboard problems
dear bangaloreboy , this may be due to your shift key is having a problem. This is permanently pressed or the other key is having some problem . If you think shift key is not causing a problem please check the key board settings from contol pannel .
I donot think this is caused by changing the operating system.
Best Regards
Feb 25, 2008 | Computers & Internet
Samsung (SP0822N) 80 GB Hard Drive Logo
109 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
