Question about Avanti EWC28 Wine Cooler
Avanti EWC28 Wine Cooler TOO Cool
My Avanti EWC28 Wine Cooler is way too cool. I have it turned all the way down and the "warmest" I can get it at is about 49 degrees. I really want to keep my wine at 55 degrees, which should be very normal for a wine cooler. My email is peteysilvercreek@yahoo.com if you have any ideas.
Thanks! Kristy
  • Petey33 Jan 03, 2008
    Will do - thank you!!
  • Anonymous Mar 15, 2014
    avanti wine cooler not turning on
    President:
  • 1,314 Answers
Contact avanti cust svc they are easy to work with and want you happy tell them your promb but i suspect you need a new themostat
Posted on Jan 01, 2008
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
My Avanit WC54 wine cooler turns on, however it does not cool. Every few minutes it makes a clicking sound
if you are handy go to a refrigeration supply hoese and buy a 3-1 pack remove the wires from the compressor let it cool if hot and hook to 120 volts wiring it shows you on the package..........luck
Jun 16, 2011 | Avanti WC54 Wine Cooler
I have a Avanti wc492d wine cooler that is not working. The unit shows power(lights are working) but it will not cool at all. I can here a click sound when I change the temp set, but the cooler will not...
The issue could be the cold control, timer, wiring, or the compressor.
The temp control has to be closed for voltage to get to the timer. The timer then calls for the fans and compressor to run. The timer could have stalled after a defrost cycle or the cold control could not be sending voltage to the timer.
Jan 28, 2011 | Avanti WC492D Wine Cooler
Wine cooler has no light or power working it simply shut down
you want to check power coming into unit... do you have power at the switch... there was alot of issues a ton etime with there power control switches and thermostats... check incoming power to unit and see if the switch has failed... also these units have small controls on them that will fail from time to time. you are going to have to see where power has failed at.
Jan 03, 2011 | Avanti EWC28 Wine Cooler
Model # HDWC35 Wine Cooler is not cooling at all.
Thermostat failure in those is very common. One quick test is to bypass the thermostat. And if it runs, you need to replace it.
Dec 12, 2010 | Avanti EWC28 28-Bottle Thermoelectric Wine...
Moved cooler and wont restart
try leaving unplugged for a couple hours then plug back in
May 18, 2010 | Avanti EWC28 Wine Cooler
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
My cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
May 27, 2008 | Avanti EWC28 Wine Cooler
AVANTI WC40D
it is replace able but if you get the new door is better for you.
Dec 25, 2007 | Avanti EWC28 Wine Cooler
Avanti EWC28 Wine Cooler Logo
546 people viewed this question
Top Avanti Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Avanti Furniture Expert? Answer questions, earn points and help others
