Question about Kitchen Appliances - Others
Drip Pan for Electric Griddle Melted
I received a brand new griddle for Christmas. The first time I used it, the drip pan melted to the griddle. We had to pry it off the pan. It was melted so badly that it can't be used again.
  • 579 Answers
Take it back for a refund. What make and model was that? I'll remember not to buy one of them.
Posted on Dec 31, 2007
I need a drip pan model #169026
Ebay or
Griddle Pan Electric‎
Adwww.amazon.com/kitchen‎rating for amazon.com
Up to 50% off Griddle pan electric Free Shipping on Qualified Orders.
Ratings:Website 10/10 - Shipping 10/10 - Selection 10/10
Jan 28, 2016 | Kitchen Appliances - Others
I have a brand new kenmore oven. I did not realize that the burner is under the bottom of the oven. I put an aluminum drip pan on the bottom of the oven and turned it on for the first time. The pan is...
You may be able to scrape off the remains of the pan but you must be careful to avoid damaging the oven lining. The alternative is to buy a new oven.
Nov 27, 2013 | Kenmore Ovens
Did not realize that burner was under the bottom of stove. Put in an aluminum drip pan on the bottom and turned ove n on for the first time. The pan is now melted to the bottom of my brand new oven. ...
Can you see that the pan has actually melted, or is it just stuck? Aluminum melts at over a thousand degrees, an oven only gets half that hot.
Try to pry it up with a putty knife.
Worse case scenario would be sanding it out with a rotary power sander after cutting as much out as possible with tin snips.
I need a replacement plastic drip pan for a Rival GR210 Electric Griddle
I have one that I am listing on eBay right now. I know its an old question but maybe this will help someone else.
McGavin - nwtradepost
Dec 29, 2010 | Rival S160
There is a green wire with a 2 prong female end in the center back of the cook top. where does this attach I have looked and felt everywhere. I spoke to tech support he said it was the grease pan ground....
Angeashmore: We had the same green wire problem. The catch is that the 2-prong female plug just looks like it should receive a matching 2-prong male plug. In fact, at the center back of the pull out Drip Tray there is a very small flange next to a small hole. That flange slips right into the plug, but under those two prongs which then hold it in place. Its length allows you to disconnect when you remove the Tray for cleaning, but if that's the first time you spot it loose, you'll think it plugs in somewhere up front and will look in vain for a matching 2-prong male plug. I'm guessing they provided a ground for the Drip Tray since it is otherwise fully suspended on nylon rollers. No instructions about this in the set-up manual, so likely omitted frequently. It's just a ground wire, and won't really fix anything else, and would appear to work just fine without it, but just a safety feaqture. Confirmed by tech support at Viking on 1/24/2011. Your initial post put me on the path to success here, so thanks! .....Jim
Nov 29, 2010 | Viking 48" 6 Burner, Griddle Professional...
Is there a cleaning manual for my 6 burner/griddle viking range?
I have a product that I use to clean my burners and griddle with, it is made by ECOLAB and is called Greasecutter Plus. It doesn't hurt the range but it makes it look brand new, even my griddle comes completely clean. You just spray it on then let it sit for a bit then it wipes clean.
Apr 18, 2010 | Viking 48" 6 Burner, Grill Professional...
Can you cook hamburgers and pork chops on the griddle hot plate?..if so, should there be a drip pan beneath the holes in the griddle to catch the grease?
There should be a drip pan already but remove the griddle and line it with aluminum foil that way you can just roll up the foil and throw away and you don't have to clean the drip pan. If you cook pork you need to cover with a lid and you want to make sure you get the meat hot enough to be safe, get a thermometer from Wal Mart and it will have a probe and the temp the meat has to be in order to be safe. Chicken is 160 beef is 140 and I don't eat pork and don’t know the exact temp for it but the problem will have it on it. If this helped please rate me.
Aug 07, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Foil drip pan melted to the bottom of oven? Will it burn off?
IF YOU CAN REACH IT IN EASY SO YOU CAN USE A SUITABLE TOOL LIKE TWEEZER
BUT REMEMBER IT MUST BE OUT OF WORKING COOL CONDITION FOR 1 HOUR MINIMUM TO AVOID SCALDING.
THANK YOU
Jul 08, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Appliances - Others Logo
172 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
