Question about Hoover U5507900 Elite Rewind Bagless Upright Vacuum
Reverse Suction My machine is blowing out instead of suction.
    President:
  • 1,673 Answers
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Posted on Jan 15, 2008
How to make the vacuum blow
Not sure about your machine but normally there would be a fitting on the "exhaust" side where the hose can be attached or if its an electronic control, it should be on the machine.??
Nov 19, 2016 | Kenmore Vacuums
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
How do I get my Shop Vac to suction instead of blowing?
Unlatch and remove the cover, then reseat it and latch it to restore suction.
Feb 05, 2015 | Shop Vac Vacuums
We have a dirt devil that when the canister is engaged, it no longer has suction. The canister is empty. Thoughts?
you turned the switch to blow instead of suction
remember them days .. no .. i do
Jan 12, 2015 | Hoover Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Wheres reverse suction
Uprights don't normally have a reverse suction.
Feb 24, 2013 | Dyson DC25 Animal Bagless Upright Vacuum
Not much suction
Check that the bag and filter are clean.
Try it without the hoses and fittings, If there is better suction the hose has a blockage. Reverse the hose and and hold it against the inlet on the machine and let the machine **** though the hose backwards. This sometimes clears a blockage.
Feb 11, 2011 | Bissell Vacuums
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
Stop vacuum from blowing to suction
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559995
Generic problem for all Vacuums
Posted by keyerica74 on Apr 30, 2008
Stop vacuum from blowing to suction…..
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You’re vacuum is blowing because your (round vacuum) belt is on backwards and is blowing instead of having suction – please reverse the belt and most vacuums have a diagram on the bottom of the vacuum to tell you which way to install. Not knowing the brand name or model #, if you have Questions, Contact you local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
No Suction
It should **** back up the water as you move along.
It seems like you have a suction leak or it is plugged with debris.
I would take it apart and clean.
Mar 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover U5507900 Elite  Rewind  Bagless Upright Vacuum Logo
1,158 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
