Hello rdblum, Dave here! I can tell you that you most likely have a bad T-con board also known as a Timing control board! P/N:3240WTC4LV0.5 (((( Please make sure this is the same part # you have on your T-con board before you buy a replacement board!)))) If you replace this board it will most likely fix your TV buddy!
Just to give you heads up! There is a 10% or less chance that the LCD PANEL it's self is bad! I my self have only come across this type of problem where the panel is bad once in the past two years! I have also done this repair at least 14 times in the last two years on an LN-S4051DX & LN-S4041DX!
Please feel free to call or message me if you have any other questions! All others are also welcome to call or message me if you need help with you LCD or PLASMA type TV!
Thank you! :-)
Dave 1-503-432-9904 pleasefixitdave@yahoo.com
Comments:
Nov 02, 2009
- I recommends
ordering by the part number off of the board in your TV whenever possible. Often times you will find that TV
models with the same model # may have different board types in them and use more than one set of parts and/or panels.
progressive multiple static type horizontal lines across the LN S4041 LCD screen started with one...
(More)
progressive multiple static type horizontal lines across the LN S4041 LCD screen started with one thin line several months ago but when I switch channels or input for one second screen is normal. Not dependent on source or input even removed power for 1 hour -progressive deterioration - sound and other function intact underlying picture sharp/ also where can purchase the background 40" lights one is broken unrelated to this problem
