Question about JVC AV-27D303 27" TV
Cannot access the tv menu/use audio or visual devices
I purchased a tv through craigs list, the model number is pcw227c321 it is listed as 27" WIDE HOTEL/MOTEL AV SMART. I have hooked a dvd player and an x-box into the television but I cannot seem to get them to work. I cannot access a menu for the tv manually or through a universal remote. Do you have any suggestions?
SOURCE:
  • 10 Answers
SOURCE: can't find code for JVC AV-27220 tv remote
Hi Please follow this link and u can get the full manual to fix the problem.
Please review and say if it helped thanx
<a href="http://www.nodevice.com/manual/newmans/AV-27220pdf/get16984.html">Download JVC AV-27220 Service Manual</a>
Posted on Apr 19, 2009
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
  • 5 Answers
SOURCE: turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. [email protected]
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Posted on Feb 04, 2009
  • 106 Answers
SOURCE: How to remove closed caption from JVC TV without original remote
Try to get a univarsal remote a desent one at 15$ at walmart then try to use menu to, or unplug for 15 min then plug back in these should work.
Posted on Mar 19, 2009
jdvillanueva
  • 2098 Answers
SOURCE: JVC 27" TV model do not know what are the codes
Hi Roger,
You didn't mention the brand of your universal remote control. Anyway, here are the universal code for JVC Tv.
JVC Codes: 013/ 054/ 055/ 060/ 065/ 067/ 089
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 15, 2011
What is the tv code for Craig mocel # clc503
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Nov 23, 2015 | Craig Televison & Video
LOST REMOTE ON A SONY MODEL # KV-32TW67 HOW DO I USE BUTTONS FROM FRONT OF TV TO GET TO THE MENU PICTURE AND AUDIO NEED TO BE ADJUDTED DONT HAVE REMONTE HELP ME
If there is no 'Menu' button at the front panel of the TV, you should have a remote control to select the inputs. Most models of Sony TVs won't have this button.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Oct 02, 2014 | Televison & Video
Cannot access menu for a 24MC4306 remote and TV no menu button ??
Without a remote control, you can't access its Menu mode. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Dec 18, 2017 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
How do i remove channels from favorite list on craig tv
Consult the owner manual or if do not have try to Google the model number with "manual".
Apr 27, 2012 | Craig CTV-41331 13" TV
How do you delete unwanted channels form the
one way is to re scan your channels from the menu option but choose the manual channel search that way you can choose exacltly the channels you want.
Apr 15, 2010 | Craig CTV-41304 13" TV
Need Remote Control For 1992 RCA TV Set
There should be access to the menu system from the panel controls. Either a menu button or pressing a combination of buttons for a certain period of time to access the menu.
Oct 06, 2017 | RCA F27450 27" TV
Service Menu RCA HD56W58 56" TV
http://www.hdtvoice.com/voice/showthread.php?t=24248
go to http://www.thomsonnetwork.com
Click on "publications ordering" (in the list on the lefthand side of the homepage)
Click the box for service information. Enter the model number (or click the chassis button and enter the chassis number).
In the list of documents you can purchase for $40 ESIATC32X -- the service manual on CD for your set.
This disk will have the info you need.
If you do decide to purchase it (and I highly reccommend you do so), send me the alignment chapter and I would be happy to post it for others who have the same set on my homepage.
Jan 28, 2008 | RCA HD56W58 56" TV
JVC AV-27D303 27" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
