HP Pavilion a305w  PC Desktop
Problem for HP Pavilion a305w (DM181AR) PC Desktop
PC will not turn on....plugged into power supply
By warpedlenz on Oct 24, 2009
PC will not turn on....plugged into power supply the system only blinks rhythmically at me and will not respond to On button. What part of the PC needs to be replaced to work again?
Solution #1
posted on Oct 24, 2009
Not Rated)
efs_perpends
Rank: Guru  HP Expert
Rating: 89%, 712 votes
Please start by working through this HP support article for your power issue. Having said that, the most likely culprit in such cases is the power supply itself. Even if some lights are lit, it could be bad. You can have it tested easily by a local computer tech, who can load test it to be sure it has indeed failed, and usually provide you with a replacement for about $30.00. If you want to investigate testing it yourself, see the links to do so accessible from this general startup troubleshooter.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Was this helpful?
Yes
No
Solution #2
Not Rated)
lovepirat
Rank: Wiz
Rating: 78%, 62 votes
blinks when? right after you turn it on?
any way try removing the bios bettery for a copple of hrs and incase, remove the video card(if u have a build-in u dnt have 2 :)), and the memory(ram)...and wait a bit, then try again.....
Was this helpful?
Yes
No
Solution #3
Not Rated)
mbostermeyer
Rank: Wiz
Rating: 79%, 7 votes
Actually, the blinking is a troubleshooting code. HP and Compaq computers bling and sometimes beep a different sequence of codes. If you find the troubleshooting codes for that certain pc on HPs website then it will tell you exactly what is wrong and what you need to replace.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion a305w PC Desktop
Questions and Unsolved Problems for HP Pavilion a305w PC Desktop
Do you recommend HP Pavilion a305w (DM181AR) PC Desktop?
Answer
Answer
cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will... (More)
Answer
my compaq persario 6000 needs to be restored, i have lost the floppy drive needed what can i do. ... (More)
Answer
I made a ecovery disk and it loads and then works, at the botom it says examining 19092 and I'm... (More)
Answer
connect to gnutella network
Answer
i can not get to the cashier in my william hill account
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Pavilion a305w PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
