Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Mitsubishi 65831 I have a 65" Mitsubishi tv (model WD 65831) and is only about 9 months old. I heard a pop come from the rear of the tv and now there is no picture at all. I tried resetting the tv but all I get is a popping/clicking sound from inside the tv housing. The audio still works. Any ideas?
  • Anonymous Mar 29, 2014
    picture and sound quits in about 10 minutes
  • 579 Answers
If the lamp has failed, don't fall for just paying big $$ for a new one from Misubishi. Instead, of buying their whole lamp assembly, just buy the bulb from me or many other sources on the net and install it into the assy yourself.
Posted on Dec 31, 2007
    Novelist:
    Scholar:
  • 136 Answers
Sounds like the projector globe is gone. i think you will need to replace it. if you are lucky there should be a pannel on the side or rear of the tv that allows you to replace the globe. pricey though.
good luck
smeags
I have a Mitsubishi WD-60738 - about 3 or 4 years old. On Sunday heard a electronic 'popping' noise and TV turned off. When I turn it back on, i get audio, but no video - screen stays dark. Did my
Check and replace the damaged component/s at its main power supply regulator section circuit. The sound you heard might be due to a busted capacitor. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 24, 2014 | Mitsubishi WD-60738 TV
Mitsubishi WD-52525 Rear projection hdtv I just turned my tv on and after about 1 minute I heard a pop, and the tv turned off. I tried turning it back on, and I have audio, but no picture...what could...
cpvsmv,
Your lamp blew. Hopefully the power surge did not take out the ballast. You need to get a new lamp. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will not only tell you where to get the lamp at the best price but also walk you through the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Heard a big popping sound then the screen went black and the red light when on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jul 02, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
I have a 4 month old Model WD-73736 tv that is nonresponsive
i'd take it back!  it's obviously defective.  TV's are supposed to last longer than 4 months!
Mar 27, 2009 | Mitsubishi WD-73736 Television
HEARD LOUD POP NOISE DLP TV DOES NOT WORK
Following up on my Feb 7 post. My new lamp arrived, and I replaced it and it works great. The old lamp had many shards of glass come out of it. It was tore up. I saved some money buy purchasing just the lamp and not the cartridge. It's a little bit more work to take apart, but saves money. Mitsubishi wanted $289 for the lamp replacement kit. I got a lamp for $114. TV is working just fine now!
Jan 30, 2009 | Mitsubishi WD-57734 57" HDTV
I need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Dec 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd 57731 1080p
see if there is dust inside blocking it.
Jan 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
310 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
