Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips tv i have a 27st220l with a shorted 7460 horz out replaced it and still dose not come on but has not blown out again. would it be a open resistor or cap ? can anyone help me please?
  • 579 Answers
Do you have B+ voltage? If yes and the TV is maybe 10 years old plan on doing the flyback as it is going to cause trouble even if it isn't right now.
Posted on Jan 01, 2008
Phillips 27ps55s121cc wont turn off w original remote or tv menu is this board level prob?
Yes, the entire main board used to be (you would have to ask Philips) available but we gave up (where I work) ordering them as too many were damaged or destroyed in shipping.
Board level repair:
check fuse
check power supply voltages
check for short to ground at horz. output transitor
etc
Mar 17, 2012 | Philips Magnavox MS3652S 36" TV
Panasonic ct 32hx42f blows main fuse
Blowing fuse points to high voltage transformer being short. Check the primary coil of the transformer first.
Dec 14, 2017 | Panasonic CT-32HX42 32" TV
Please helf
Check out this site for the correct codes bud.http://www.thompsontv.com/rcarc.html
Jul 30, 2008 | Philips RC2573 Remote Control
No picture no sound
most likely the horz output is blown and voltage regulator is shorted. I f you have a muti meter you could check if they are shorted that will tell me if the power supply is ok.
I beleve at this time you should be careful this is high voltage off of flyback is 30.000 volts
See if there is a local repair shop who charges cheap road calls. I think you are
looking around 295.00 to fix.
thanks DOCTOR VIDEO
May 17, 2008 | Philips 9P6031C 60" Rear Projection...
No picture, no sound, just chirping noise coming from back
NO - - signal did nothing to the set... Sounds like a shorted HOT (horizontal output transistor) and the feedback your hearing (chirp) is on the horz. transformer as it tries repeatedly to startup... Don't allow it to do that for too long...
Bill
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Play for 1Hr then short out Hor out tran 2SD1556
If horz output keeps shorting then the high voltage flyback is bad.
Dec 11, 2007 | Philips Magnavox 51MP392H Rear Projection...
Sony TV not working
This is not an easy fix for most people! I suspect the ps is blown, R607, Q601,Q602 (use all org Sony parts, lots of factory 2nds around). This stuff blows to protect the fuse!!!!! Very rarely the input bridge rectifier or filter cap short.
Check R622, if open or discolored also replace VDR601(doesn't go bad very often). Check Horz output Q502. Inspect whole board for any bad connections, all parts with heat sinks(regulator ICs). Horz driver transformer, 0.47uf to horz driver tr. There could be other parts bad (flyback??). Make sure no supplies are shorted, check audio output supply, vert output supply, etc. Easily $150 repair at a shop. Good luck!
Oct 27, 2007 | Sony KV-32S36 32" TV
Blown fuse 1.25amp Board pos. 1452
The main fuse should be a 4 amp fuse not a 1.25 amp.
Jan 26, 2007 | Philips 32PT6441/37 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
