Question about Canon i9900 InkJet Photo Printer
How do I access the waste pads now that I have all the covers off. Where are the two screws from the outside bottom into the metal assembly?
  • 4,345 Answers
Canon i9900 waste tank reset
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
I just cleaned out my waste absorbers on my canon i9900. Once you pop the cover off (which took me an hour to figure out how to do), you will need to unscrew all the screws you can find (I found 7) - then you can lift the entire body of the printer out of the case and you will see the 2 HUGE white felt-like pads that cover the entire bottom of the printer. This will also have 5 smaller pads stacked on top.
You can remove them, clean them, let them dry, put them back, and hope that you screw the printer back together properly.
I managed to get mine to work again, but for some reason none of my colors will print...only black :-(
Posted on Mar 04, 2010
Yellow flashing 5 times then goes to green and back to 5 yellow
Help I9900
Posted on Feb 23, 2010
Can you give me a wicreset keys for epsonL210
Is the waste pad full ?
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer.
Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way.
Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Note: This information and a couple of photos are also available on Steve's Digicam Forum (http://stevesforums.com/forums). Goto Printers-Photo Inkjet-Epson R200-210 & R300-310 Mod
Nov 09, 2014 | Epson Stylus Photo 2100 InkJet Printer
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
I have an Epson R200 printer and need to dismantle it to gain access to the cleaning pads to either replace them or wash them. How do I dismantle the printer without breaking any of the small plastic tabs...
You can see the waste pad by opening the access panel on the back of theprinter. Open the access panel on therear of the printer (remove screw) You will see a tube (down and to yourleft) coming from the cleaning pump and it will have an open end onit. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it tothe outside of the printer, thru the access panel. Find yourself a suitablecontainer (Tupperware or a plastic cup or jar) that is not too tall. Putthe tube into this container and secure the tube and container so they won'tcome apart or lose connection if the printer is moved. If you wish you can makea hole or notch in the access panel cover so it can be replaced. Now the inkwill go into this container and not into the waste pad inside theprinter. If it gets full, dump it.csts_7.jpg
Mar 04, 2011 | Epson Stylus Photo R300 InkJet Printer
How do I remove the Waste Ink Absober and do I
The waste ink pads are under the printer and cover the whole bottom of the case. You need to remove the scanner from the top, the side covers, the main case middle cover, unplug all cables from the logic board, lift the print engine up and out and replace the pads. After that you need the service mode to reset the counter if it runs after re assembly.
Feb 09, 2010 | Canon PIXMA MP170 All-In-One InkJet...
How do we change the waste ink absorber in a cannon inkjet printer? Thank you
Unplug printer, open top of the printer lid ,Once the case is off, you're looking at the guts of the printer sitting in the tray-like base. To get at the blotters and waste ink, you'll need to get under the printer body, which is held to the base by three or four screws. The older your printer is, the easier it will be to find the screws that hold the body to the base If you have a good magnetic screwdriver, that will be very helpful. It may also be helpful to take notes and/or pictures of where the screws are located to make re-assembly easier ,you will find small pads ( about 3/8 x 1 inch)under where the ink cartridges sit. They are grundgy, so I take them out, clean it with a kleenex or replace as in the case , clean out the slot that they sit in before replacing the pads. hope this helps
Jan 11, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Genaral error
Probably the waste ink tank is full.Follow this procedure:
1. Press and hold "Stop", "Maintenance", and "Power" buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off.
2. Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That's all there is to the reset procedure.
If the waste pad is actually full and ink is about to overflow, then you need to install a waste container.You can see the waste pad by opening the access panel on the back of the printer. Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way. Open the access panel on the rear of the printer (remove screw) and look inside carefully with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel. Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved. If you wish you can make a hole or notch in the access panel cover so it can be replaced. Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
Oct 15, 2009 | Epson Stylus Photo R300 InkJet Printer
It says waste ink near full where is this waste ink located?
The waste ink absorber for this machine is on the bottom, the whole case is covered at the bottom with absorbent pads. The pads are cheap, but you need to access diagnostics to be able to reset the error code after they are changed.
Jun 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer sending message
Waste ink tank/pads getting full.
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need to actually get a SERVICE MANUAL, to refer to that removal procedure.
You may want to try doing a general search on the "Fixyourownprinter.com" printer repair site, under WASTE INK PADS or WASTE INK COUNTER RESET PROCEDURE.
Jun 22, 2009 | Epson Office Equipment & Supplies
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
How to change waste pad??
hello!
try this and check if it will work:
1. Press and hold "Stop", "Maintenance", and "Power" buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don't have a screen so just wait until the 10 seconds is up. 2. Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That's all there is to the reset procedure. Is the waste pad full ? If the waste pad is actually full and ink is about to overflow, then you need to install a waste container. You can see the waste pad by opening the access panel on the back of the printer. Changing the waste pad requires almost complete disassembly of the printer, it is a big job. There is an easier way. Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad. Use a piece of coathanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel. Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won't come apart or lose connection if the printer is moved. If you wish you can make a hole or notch in the access panel cover so it can be replaced. Now the ink will go into this container and not into the waste pad inside the printer. If it gets full, dump it.
May 06, 2008 | Epson Stylus Photo R220 InkJet Printer
Canon i9900 InkJet Photo Printer Logo
899 people viewed this question
Clive
Clive
old marine
old marine
