Question about Canon PowerShot S1 IS Digital Camera
Purple hue on image or vertical lines (noise)..viewfinder has normal color or flickers
I can put in fresh rechargeable batteries and still get negative like or purple hue or black and white photos even when color shows on viewfinder. Is there a factory reset to wipe out any wrong buttons pushed? I take a lot of indoor shots in rapid succession...will it overheat and cause a loose solder connection>
It has been intermittently going down-hill slowly for 3 weeks. I have loved this S1-IS and it has never given me problems. PC 1058 (Japan) Serial 8724311117
Dave
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 31, 2007
I had the same problem and used the solution posted here (recall). They responded very fast and sent me an refurbished Canon Powershot S5 1S camera. I am not sure if I should receive the new one or insist my old one to be repaired.
Posted on Jan 10, 2008
Sony Cybershot viewfinder shows vertical lines nothing visible in viewfinder only vertical lines in colors can't get focused picture in viewfinder or picture. Please help!
CCD Imager in your camera is probably defective and needs to be replaced. If the unit is still under warranty, i advised to have sony fixed the issue for you.
Jul 17, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Sceptre 47inch flatscreen lcd has purple line vertical 2 inches from left through entire screen and all channels
is it solid lines or do they flicker, come and then go based on what colors are on the screen. Also does the interlace spread the horizontal line from top to bottom and bright colors?
Jun 20, 2010 | Televison & Video
White and purple flickering vertical lines. No image or sound.
I Hope this helps!
Sony has extended the Warranty for people experiencing picture anomalies due to LCD Panel failure through October 31, 2012.
See here:
http://esupport.sony.com/US/perl/news-item.pl?news_id=378&template_id=1
IF YOU FOUND MY SOLUTION HELPFUL PLEASE VOTE 4 THUMBS UP.
(any less hurts our averages)
Thank and Good Luck!
Jan 04, 2010 | Sony KDL-46XBR4 46 in. LCD Television
Fiji finepix s7000
Hi. From past experience I would say that these symptoms suggest the early stages of CCD failure. It usually starts with lines etc as you describe and progresses into wavy, blurry pictures or partial pictures and eventually the ccd just goes black. If it is CCD failure, the camera will usually still work when viewing pics that are already on the card.
Jul 02, 2008 | Fuji FinePix S7000 Digital Camera
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Vertical lines
This is a defect in the CCD ( light sensor ) - check with Canon and they'll replace it free of charge even if the camcorder is out of warranty.
Jun 16, 2006 | Canon MV600 Mini DV Digital Camcorder
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
377 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
