Intermittent spark, new spark plug, no start
...chainsaw cs 38cc smh038ub24ra em. u.s. epa ph-1, 95-98 ca. emissions regulations for ulge's. d048 Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of ...
Most often there is a dust-oil clog in the bottom of the bar slot which closes an oil passage between the bar slot and the hole drilled half way through the side of the bar. This provides a passage between the thin shim plate with the two bar bolt holes beside the bar and through to the oil tank or pump output. You can remove the bar and chain and punch out the blockage in the bar with a paper clip if the chain is removed. Make sure the wire can be pushed from the bar slot right through the side hole in the bar. A gravity feed chainsaw should leak right out into the slot of the shim plate, a button pumper should squirt out there with the bar removed. With a button pumper you may have a tiny check valve in the line or the push button to take apart, replace the spring or unstick the ball inside the check valve. This is why they went to the gravity feed oil system which just leaks in there and gets picked up by the bottom of the links as the chain races past the passage between the bar side hole and the chain slot.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here: Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered (I did not get any hits). http://www.arboristsite.com/showthread.php?t=72322 HTH Lou
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Remove your flywheel cover then unhook the small wire from the magnito (coil). Tuck this wire out of the way. Reinstall your cover than start the saw. If your spark remains constant you have a short in the kill circuit or something is bent or misaligned between the off switch and the kill wire. If you still get intermittent spark, your magnito is going bad.
Since You weren't Model Specific...I assumed you meant a Poulan Pro 38cc, here's a Contact Site for OEM Manuals: http://www.poulan.com/poulanpro/manualSearchResultsAJAX.do
