big red
go on to you uninstall programs in control pannel start un installing all your un used programs making sure not to uninstall programs u need then restart and then you can defragment your c drive and restart and it will sign on as if when you first got it
Download a free program called CCleaner. Run the two top choices on the left side box. The first will remove tons of software that is not used on your system and the other will clean up your Registry.
Works every time!!
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
I have a e machine model 633ID tower running windows xp o.s. I installed a used harddrive that works...
(More)
I have a e machine model 633ID tower running windows xp o.s. I installed a used harddrive that works fine have pc up and running after installing windows updates on restart screen flashed disassembly prohibited went to white e machine logo screen keyboard is unresponsive please help nongeek
i have 633id e tower i changed the hard drive worked fine then on a reboot flashed disaslemby...
(More)
i have 633id e tower i changed the hard drive worked fine then on a reboot flashed disaslemby prohibited went to white logo e machines now it will not do nothing
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and...
(More)
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and boost the battery but it went into hiberate and wont restart or work. Is there a switch that I have turned off by accident under the laptop?
