Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer it seems to be stuck on the ultra hand wash. the only button that does anythinbg is stop. i have unplugged it time and again, but nothing changes
    New Friend:
Keep it unplugged for at least a half hour -- if nothing solves it you probably need a new board. Ours is going the sidewalk on junk day because of this. Have had it 7 years and more than a dozen service calls on it. Have had the board replaced 2x and the pump 4x -- other calls were techs trying to figure it all out. Garbage machine.
Posted on Oct 26, 2009
SOURCE:
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso beeping
The washer has a stuck keypad on the console. One of the buttons are stuck and the washer thinks you are holding that button in so it is beeping and will not allowing you to select anything else. It is hard to tell which button it is, although narrowing it down does not help anyway. The console with keypad is sold as one piece and would include the whole console facia and all the buttons. The model number provided is missing 2 digits on the end (ex. GVW9959KL1) and color is also needed for part number but they all seem to retail for $181 or close.
Thank you
Please rate this post
Jan 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer it seems to be stuck on the heavy cycle no matter what i dothe display says 53 mins it wont do anyhting wont start if i hit the button wont let me choose another cycle like quick...
I just ran into a similar problem. Ours was stuck on Normal with 42 min. Started beeping every couple minutes last night after bad rain storm. Couldn't get it to stop. it would turn off if I hit stop and a couple minutes kater (like 2min) it would come on by itself. Left it unplugged overnight until about 6:00pm. Plugged it back in and it wnt right back to the normal mode after about 2min. HOWEVER, I keft it sit with the lid open and it beeped every couple minutes for a while then suddenly stopped. I checjked it and it is off, hasn't come back on. I haven't tried to run a load through it yet, so I don't know if it is fixed or not..
Oct 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Washer starts then stops then starts and stops
With this Washer you are going to need the Factory Repair Manual. It will give you all the diagnostics and troubleshooting you need to find the issue and repair it. This are rather involved machines and you will need the guidance of the manual to better assist you on this. Especially when it comes to getting into the machine to replace the defective parts.
Download Whirlpool Calypso Washer Repair Manual
Good Luck
Jan 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Whirlpool Calypso - Will not start
You ever hear of dog years? Well Calypso follows those same guidelines. So your machine is 35 years old. These are the Edsel's of washing machine fame. I had a Calypso for 6 1/2 years. 3 pumps, numerous circuit boards, drive motors, phone calls and arguements with Whirlpool, along with machine downtime. I finally junked it and bought a Whirlpool Duet 9200 HT (get the made in Germany machine). A world of difference in wash quality. Fresh smelling unballed clean clothes. The Calypso was removed from the market and the subject of a class action lawsuit. Just Google it and start reading. Get comfortable first. There's a lot to read.
Nov 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
83 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
