LOC indicates that the Control Lock has been toggled on. This prevents accidentally turning on the oven while cleaning the control panel. Toggling this on and off depends on the model number of the range/oven. For some models, press and hold Cancel and Cook&Hold for three or more seconds until the lock goes off. Press Cancel first; this is for models with the following manual https://outlet.whirlpool.com/digitalassets/RY160LXTS/Use%20and%20Care_EN.pdf . On other models, press and hold Start for the three seconds. This is the step for a recent model, WFE515S0ED
, https://images.homedepot-static.com/catalog/pdfimages/8b/8b4d9bd3-3c98-42ee-a764-c2e1ddf36914.pdf . On this model, there is a padlock symbol and text next to the Start button indicating how to toggle the control panel lock.
Please add a comment with the model number of your Whirlpool appliance for the directions to toggle the control lock on and off for your model. I hope this helps.
Step 1
Open the oven door. At the top, left-hand corner of the open oven, locate the model number tag.
Step 2
Check under the burners. Lift each burner on the stove off to see if the plate is underneath. Do this if the plate is not located on the inside of the oven.
Here is the link to LG appliances LG RANGES OVENS Support
I entered the number you provided and it couldn't find a match; you might want to re-check the number, or look at a model close to yours.
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
