Solution #1
posted on Oct 27, 2009
Rank: Guru
Rating: 88%, 39 votes
-Taken From GameFAQ's-
World 4-4: Six-Face Sal's Fort
Flower 1
Starting off, go right and hop across the yellow platforms. When you reach
the lava monster, wait for it to stop spewing its lava stream in the air; if
you touch it, you die. When it stops, continue to the right, hopping across
rotating platforms. Pick up the red #1 ball when you reach it, then throw it
in its slot on the wall. After the metal gate opens, continue to the right
and eat the Shy Guy. There will be three sets of yellow platforms ahead. Hop
from the first set to the higher middle set. Jump above the platforms to get
two red coins (2), then continue to the right.
To the right, you will come to a series of purple platforms attached to a
gear. Hop on the right ledges to raise the block to the right. Once it's
fully raised, jump from the highest platform on the wheel onto the block.
Shoot the winged cloud above the block to get the first Flower.
Flower 2
After you get the first flower, drop to the ground and head right into the
next room. There, go right and jump to the ledges above. In the upper-left
corner, you can reveal a hidden winged cloud containing five stars. Go
through the Middle Ring to the right, and look above to see three targets for
the numbered balls. You don't have any right now, so drop to the bottom area
and follow the coin line to the right.
At the Stork Stop, switch to Baby Mario, then continue right along the bottom
path. Make eggs from the Shy Guys that spawn from the pipe, then enter the
door to the right of it. Pick up the red #1 ball sitting there, then exit the
room. Jump onto the pipe and then to the thin ledges above it. Hop up the
ledges to reach the upper-left area. Ride the green platform upward, then run
to the right past the spike pit. At the other end, collect two red coins (4)
and the green #2 ball.
Now, quickly run back to the left as the floor rises to escape. Drop to the
area below and head directly to the right this time. When you reach the
upper-right ledge, go right and enter that room. Lower the two blocks by
turning the gears (stand on the right side of the wheels). Then, hop onto the
right block and flutter to the left one. Go left and up the first hill, then
jump onto a ledge with a Stork Stop on it.
Switch to Baby DK and hang from the ceiling to get across the spike pit to
the right. At the far right, drop to the ledge below and enter that room.
Switch to Baby Mario and run to the left, and pick up the Key. As soon as you
touch the Key, the ceiling will start to collapse, so quickly run back right
to escape. Switch back to Baby DK when you reach the door, then exit the room
and get back across the spike pit.
Now, continue up the path to the pipe at the top of the hill. Go through it,
then when you arrive in the next room, flutter onto the right ledge. Go right
and shoot an egg upward to grab the second Flower.
Flower 3
Drop off the platform to the ledge below, and go through the door there. Pass
through the Middle Ring and go right to some platforms. Hop from the yellow
ones to the ledge above. Collect the coins up there and run to the left where
you will find the next Flower.
Flower 4
From where you grabbed the previous flower, jump to the ledges above and go
left to the pipe. Go down the pipe and enter the door when you land. This
time in the room, go right and hop on the left purple platforms to turn the
gear, which will roll out a ledge below. When the gear stops turning, drop to
the ledge directly below the winged cloud. Shoot the cloud to make a red
switch fall onto the platform. Before you hit it though, go left and drop to
the area to the left of the ledge that moved. Head left and drop onto the
thin ledges, then jump to the stakes in the lava below. Jump to the right to
grab the fourth Flower.
Flower 5
Shoot the winged cloud above the left platform to get five stars. Then, jump
across the ledges and head back to the right. Hit the red switch and run to
the right along the block path, collecting two more red coins (6). At the
other side, jump up the ledges and collect the yellow #3 ball. Quickly drop
back down and wait for the blocks to disappear. Then, drop to the platform
below and collect two red coins (8) above the stake to the left. After that,
go through the door.
Back in this room, go all the way to the far left end of the room. Jump to
the ledges above and unlock the door with your Key. In that room, use the
Stork Stop and switch to Baby Mario if you don't already have him. Jump onto
the M blocks and then make your way upward along the small ledges and other M
blocks. When you reach the top, enter the door on the right side. There, jump
onto the purple platform and ride it downward along the track. When it moves
under the spikes on the low ceiling, duck to avoid getting hit by them. When
you reach the winged cloud, shoot it to reveal a Flower. Shoot a second egg
to claim it.
Boss Battle
Continue riding the platform upward along the track to the end. You will
collect two red coins (10) as you approach the top. Once you get there, go
down the pipe. Fall into the next room and land on the ledge below to find
two more red coins (12), then jump to collect the Character Coin to the right
with Baby Mario. To the left of the coin is a hidden winged cloud you can
jump and reveal; shoot an egg at it to get five stars. When you're done, go
through the door at the bottom to exit.
When you appear in the main room again, grab the two red coins (14) to the
left. Then, run to the right and jump to the upper-right ledge. Go right and
look up at the colored targets, and throw each number ball at the appropriate
target. Doing this will raise a block to the right, so go ahead and enter
that new room. Ride the platform on the track to the right, collecting four
more red coins (18) along the way. At the end of the track, go through the
door to reach a new room.
Use the Stork Stop and switch to Baby Mario if you don't already have him,
then start running to the right. As the ceiling blocks start to fall, keep
running and collecting the coins. One row of coins towards the end will be in
the air, so you will have to quickly jump to get them, including the last two
red coins (20). At the end, go through the Middle Ring, then open the red
door. In the boss room, go up the hill and bounce to the area above, where
you will meet Six-Face Sal.
The boss consists of six faces on a giant wheel which hangs on the top screen
above you. The bottom half consists of a long platform of donut blocks which
sink if you stand on them for too long, and four purple platforms which turn
the gear when you jump on the sides. The battle will start off with one of
the heads coming out and dropping spiked balls onto you. To attack, turn the
wheel by hopping on the platforms, then when the head you want to attack is
at the bottom end of the giant wheel, shoot an egg up at it.
After the first hit, there will now be multiple heads popping out to attack.
Some heads will be red, but only one will have a pale, light color to it.
That's the one you should be looking to attack. After several rounds of this,
at one point having all the heads attacking you at once, the battle will end
after you attack successfully several times.
