Nothing could be easier to work on than these beautys. After
unplugging the machine start by popping the top so you can get to the
screws holding the front panel on. As
pictured gently push the
springclips in on each side about 2 or 3 inchs from each end to release
the top:
Pop that top
with a putty knife.
After removing the 2
phillips screws holding the front to the frame (near the top on each
side) and taking the wires loose from the door switch, lift the front
panel out yer way.
Remove the rear hatch and take the idler loose.
Then you can get the drum out. Grab the belt and yank upwards on the
drum and remove it out the front.
INSPECTING THE DRYER
Look for broken glides on the front panel:
5303937139 glide kit $24
The rear drum has a big
trailer ball type mount that holds it into place, over time the plastic
bearing wears out and the support under it squeals,
(it is telling you
serious stuff is going to happen) The metal mount under the by now
thin, failed, and gone bye-bye plastic bearing, will eat into the ball
and cut it off causing the drum to fall into the heater element AND
break the belt. YIKES! NOT GOOD!
Failed bearing with missing ball
The
kit (5303281153) comes with everything you need to repair the bearing.
It is about $25 bucks or less. With the drum removed and the bearing
inspected you want to take a gander at the heating element. If the
element is broken, there is no need to buy the whole pan for $100.
You can get a restring
kit for about $25. Just remember to evenly space the new wire so it
will not burn out quickly. Remove all lint from the dryer and the drum.
This is the main killer of a heater element. Lint on it causes a hot
spot.
5300622032 Restring kit $25
The fuse mounts on the
rear wall of the dryer in the upper right hand corner. If it blows the
dryer will not run. Clean out the vent and any lint in the dryer or the
fuse will continue to blow.
134120900 Fuse $12
The belt part # is 5303281154 $10 The Idler is part # 131863007 $12
For routing info see
Belt routing above on anotha page my friend. LOL
Or better yet how about
the repair manual? Here is a newer repair manual. The innards of the
dryer is the same as always but the newer models have a thermister and
assorted goodies:
ELECTROLUX REPAIR MANUAL
