Question about Epson Stylus CX4600 All-In-One InkJet Printer
Printer spooler service not running
My printer is Lexmark X1130 cannot installed
  • Epson Master
  • 1,879 Answers
I cant find tha drive to get print whit Lexmark X1130
Please visit the Lexmark website to download and install the Lexmark X1130 Printer Driver on your computer. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Sep 12, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1180 won`t install on new vista laptop
Okay this is a easy problem, the printer spooler service is turned off, just turn it on, and try to install it again, should work if not let me know.
press start and then run
OR
hold down windows key and press r
in run menu type in: services.msc
and press ok or enter
in services, you need to find printer spooler or spooler, right click on it and select properties.
make sure start up type is automatic, then press on start. Apply ok, close window , make sure the service status is running, press F5 to refresh the page.
try installing it now.
May 21, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a lexmark x3550 and it says there is no spooler, and now it says there is no printer.
Verify that that the Print Spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print Spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print Spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try uninstalling all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print Spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print Spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 29, 2008 | Lexmark X75 All-In-One InkJet Printer
I need lost my Lexmark installation CD for my X1130 printer
You can goto Lexmark's Website and download the drivers from there.
Once on the site, mouse over drivers and downloads in the top menu, then choose driver finder. in the "Search by Model" text area, type in X1130
When the popup shows Lexmark X1130, click on it then click search. Then click on the RED text marked Download Driver near the right hand side of the screen, choose your operating system from one of the drop down boxes (either Windows or Mac). once there, click on download now!
Install and Print Away!
Sep 03, 2008 | Lexmark Office Equipment & Supplies
I need Lexmark X1130 Installation CD for printer setting not the drive CD
Here is driver download page for X1130, just click here, select printer model, and download.
This is the setup procedure.
  1. Unplug printer USB from computer.
  2. Chose OS version and download the driver.
  3. After downloading run installer file, this will start printer setup wizard.
  4. Connect printer back when required from setup wizard.
Don't forget to rate the solution appropriately.
Many thanks.
Aug 29, 2008 | Computers & Internet
Spooler service stopped
remove all s/w through add/remove programs
go to www.lexmark.com for new driver set(get the full one)
re install..
try it..
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer Spooler service!
hi,buddy
you have to start printer spooler by this.
click "start btn"
click on "run"
write here "services.msc"
double click on "print spooler"
select status type "automatic"
than click on "start"
now install your printer.
Jul 27, 2008 | Lexmark Z645 InkJet Photo Printer
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
click on start ..RUN.....type cmd......type sc config spooler depend= RPCSS......click on start ..RUN......type services.msc.......look for ptrint spooler......it will be started if not then double click on print spooler and click on start.
Now try installing the printer.
May 31, 2008 | Lexmark X4270 All-In-One InkJet Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
570 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
