The error means Water is not draining fast enough from the machine. Try holding the Start/Pause and Cancel key together for 3 seconds. The Door Lock, Wash, Rinse and Final Spin LED’s should light. Any error codes should be displayed when pressing the Start/Pause and Cancel keys. Make sure that the filter is clear of all debris and accumulated fluff etc and clean it if required to remove any residue. Refer to the following picture. Remove the bottom front panel. This can be done from the rear of the machine by unscrewing the 2 securing screws. The pump sits on the right side. Disconnect the hoses and clean them thoroughly. Make sure to clean the pump impeller out as well. Also check the main outlet hose that connects to the waste pipe and ensure it is free of all debris.
I have a frigidaire affinity washer (#atf6700fe1) and getting an error message on the display...
(More)
I have a frigidaire affinity washer (#atf6700fe1) and getting an error message on the display "DR". What can I do to clear it, I think the machine thinks the door is open when it's not.
My frigidaire front loader goes through the wash cycle fine, but when it is going through the final...
(More)
My frigidaire front loader goes through the wash cycle fine, but when it is going through the final spin it makes a low moaning noise.
Frigidaire GLTF2940ES3 washer - I need to replace the door latch assembly (the part number is listed...
(More)
Frigidaire GLTF2940ES3 washer - I need to replace the door latch assembly (the part number is listed as 1317632), but i cant find that part number anywhere! have found a 131763245 but can't find my washer model listed as being compatible....advice?
I have a LTF2490ES0 Frigidaire Front load Washer that, has just stopped working, it got to spin...
(More)
I have a LTF2490ES0 Frigidaire Front load Washer that, has just stopped working, it got to spin cycle and quit. I have run Diag and i get an "E5E error" My warranty has since expired and i Called Sears and they want a $74.95 "diag fee" which is fine but I am trying to get a close estimate on what parts will cost. So might anyone know how much the common parts to fix this problem might be? so I can get an Idea prior to the Tech visit. thanks ahead of time for your help. Shane
