Home | Dewalt | 18 Volt Compact Drill Kit | How to change the bus...
Dewalt 18 Volt Compact Drill Kit
Problem for Dewalt 18 Volt Compact Drill Kit
How to change the bushes on a Dewalt DW928 14.4V
By willodoran on Oct 24, 2009
how to change the bushes on a Dewalt DW928 14.4V
Best Solution
posted on Oct 25, 2009
Very Helpful)
brewerstool
Rank: Guru
Rating: 96%, 55 votes
You will need to get part # 389025-00 which is the brush pair kit. Remove the 8 torx screws from the right side handle half. Make sure you have the drill on its side and pry the handle half off carefully. Make sure not to disturb the insides too much. You could possibly mess up the transmission setup if care is not taken. After removing the handle half you want to take out the motor, switch and transmission all together. Remove the motor from the transmission taking care not to let all the insides of the transmission fall out. You will not like having to figure out how all those gears go back into the transmission. If you have a piece of duct tape handy, I suggest putting it over the transmission so you don't hit it accidentally and send small gears flying. ( I have done this on numerous occasions) Once your transmission is safely away from the motor you can pry out the whole brush block with a flathead screwdriver. The brush block just slides out. I suggest you do one side at a time and replace both the brush box and wire. Make sure you use the correct color wire and replace it exactly as saw the original. DC switches and motors can be damaged if you wire it incorrectly. All it takes is one squeeze of the trigger to ruin either when wired wrong. After replacing the brush blocks you can reassemble the drill. Take note that there are tabs on the transmission that have to line up properly with the handle half in order to seat properly. Any questions please post and I will answer.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dewalt 18 Volt Compact Drill
Questions and Unsolved Problems for Dewalt 18 Volt Compact Drill
Do you recommend Dewalt 18 Volt Compact Drill Kit?
Answer
Answer
I need to look at a manual for Makita HR2510 Rotory hammer I think I need to add oil but Im not sure... (More)
Answer
need a replacement rechargeable battery for MAsrecraft 54-2848-4 cordless drill
Answer
i have a ryobi 200 18v drill. that will work for about a minute & it will just stop for... (More)
Answer
I need to know how to open the clutch
Answer
Hi. My Rohm Supra keyless chuck releases the hex bit when I attempt to use it to remove roofing... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dewalt 18 Volt Compact Drill...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
