Question about Sony VAIO PCV-RS530G PC Desktop
Video card upgrade on a Sony Vaio PCV-RS530G
I'm thinking of upgrading the video card on my Sony PCV-RS530G to a higher memory video card. How would this affect the power supply? Would I be limited to specific models only? Thanks in advance.
5 Suggested Answers
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Memory slots are then exposed....insert and reassemble PC.
Ten minutes tops....good luck, much better performance.
Posted on Apr 05, 2008
  • 1342 Answers
SOURCE: trying to open the case for Sony VAIO PCV-RX540
Go Here
Scroll down to Overview & General Info
Posted on Apr 25, 2008
  • 1183 Answers
This product by sony has not been designed for high end gaming. The video card on the product cannot be upgraded.
Posted on Sep 06, 2008
  • 38 Answers
SOURCE: Replacing the powersupply on a Sony VAIO PCV-RS720G desktop
Hi There,
From the looks of things that model will take a standard ATX power supply which would be available from and computer part dealer and ebay etc, get yourself a nice 400w replacement try and get a small form factor one if you can as it will be a tight sqeeze inside the case.
when replacing it you will have to open the case up (get an anti static wristband if you can, and work on a table rather that a carpeted floor) un hook all the connectors the old power supply (one in each drive and there should be 2 in the motherboard) you may have to pull the Dvd rom out slightly to get the new supply in, unscrew the 4 case screws holding the power supply from the back of the case. lift it out then put in the new one, screw it in using the case screws and connect up the internal power cables to the drives motherboard and new graphics card, close the case, plug in and voila
If you get stuck just ask and we will help
Posted on Dec 10, 2008
  • 451 Answers
SOURCE: Sony Vaio PCV-RS220 memory ram upgrades, can it be
only supports up to 1.0 GB of RAM
Posted on Mar 08, 2011
0 characters
1 Points
Video card upgrade
Check if there is any VGa slot is there
Feb 02, 2013 | Sony VAIO PCV-RZ54G PC Desktop
Can I add upgrade my graphics card for my Sony Vaio PCV-RZ502P
Best thing to do is to open the case and see if you have a PCI-Express, or AGP Slot. If you have one of these slots on the motherboard, then you most likely can upgrade the system to a better video card.
Jul 05, 2011 | Sony PCV-RZ502P PC Desktop
Are there any video cards that you can use to upgrade the 530g? I have seen posts that the power supply is an issue. If it is possible is it a matter of installing the card and disabling the onboard...
Your pc has a special graphics expansion port - AGP x8
You can insert any graphics cards which will fit the port. Check carefully, there are quite a few different types of graphics port.
Once inserted, boot up the PC, and insert the disk you should get with the card, it will have all the relevant drivers.
There should be no need to alter the bios settings, the new card will be identified by the boot process.
If power supply does become an issue, you will need to upgrade the PSU (Power Supply Unit).
Apr 26, 2011 | Sony VAIO PCV-RS530G PC Desktop
Hi, wondering if I should upgrade my sony vio pcv-rg22z and what the max upgrade on memory etc is?
Hi. I hope this information helps you out.
The rz22g model has a max memory amout of 1 gb, using two 512 mb slots.
So you can get 2 512mb pc2700 memory modules for it, as this would max out the memory just make sure that the memory is of compatible type and build. You can't just go get cheap pc2700 ram and put it in, it might not work at all.
As far as other upgrades, it has an ide interface, so probably won't be able to find a drive bigger than 500gb, but that's a pretty big drive right there!
For processors, It appears that a 3.0 ghz pentium4 w/ht is the best you can get to fit, that's if you can afford one. They can be a pricy investment, and in the long run, you could almost buy a new computer that has dual or quad core performance for about the same price.
You can get any brand of pci video card, i recommend nvidia, as it has better performance than an ATI card. The newer the better as far as models go, just get the one with the most memory for what you can afford. Most good video cards can cost about $100, but if you go to tigerdirect, they have a Galaxy nvidia gtx430 on sale right now. It has a giabyte of ram on the video card, as well as having vga, dvi, and hdmi jacks, so you can hook it up to just about anything nowadays.
I hope this has helped make some decisions, and hope that it goes well for you.
Jan 26, 2011 | Sony VAIO Digital Studio PCV-RZ22G PC...
Can I do a memory upgrade on Sony VGC -LS 37E?
the specs for your computer, it states that it is equipped with 2gb of memory 2x1gb and max at 2gb, so I doubt that any higher memory upgrade installed would work, or else it would cause your system to crash or even damage it.
Jan 24, 2011 | Sony VAIO® VGC-LS37E PC Desktop
Can the graphics card on Sony pcv v1/g be upgraded
Are there any open sockets on the board? These would accomodate more video ram. If not, I'm afraid you may have to buy a new card. Are you replacing a card from the PCIe bus? If so, simply remove it and put in your new one. If you are working from onboard Video, you need to make sure of what kind of Video Bus you have, AGP ( older ) or PCIe.
Look in your manual for this information. All should be plug n play from here.
Oct 28, 2009 | Sony VAIO V1 (PCV-V1) PC Desktop
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Video card upgrade needed.
Your Sony has an integrated video card which can't be upgraded. It does have an AGP slot where you can install a video card, though. If you tried to download the latest drivers for this onboard card and that hasn't worked, then a new VGA card is in orde. These are getting hard to come by, as the standard is now PCI-E graphics.
I would look for something like an ATI Radeon 9600 with 128 MB RAM if you want decent performance.
Mar 11, 2009 | Sony VAIO Digital Studio PCV-RX850 PC...
Sep 06, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Sony VAIO PCV-RS530G PC Desktop Logo
163 people viewed this question
Top Sony PC Desktops Experts
Carlos L. Burgos
Carlos L. Burgos
Michael Thomas
Michael Thomas
Are you a Sony PC Desktop Expert? Answer questions, earn points and help others
