Question about Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera
Dark pictures I have a Canon EOS REbel T2 with the standard 28-90 lens. It had been working fine, but now my pictures are (almost all) coming out very dark and grainy. Further, I note that if I turn the camera 90 degrees to that a "portrait" picture -- 6" tall and 4" wide, I see a dark rectangle in the picture in the bottom right quadrant. I always set the camera to full program (the green rectangle). I have been using Fuji 400 speed file of late. Do you have any idea what I"m doing wrong?
  • Anonymous May 14, 2008
    My picture are not looking good at all grainy and just not good>
Check whether the ISO rating set in the camera is correct. Also, if the images are grainy and dark, it may be an issue with the exposure.
Posted on Jan 30, 2008
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Very dark pictures
hi melissa,
your problem is the focusing areas, im sorry that I do not know how to turn it off, the rectangle you see is the area is focusing on, and the darkness is what the camera doesnt focus on, try reading the manual, or turning it off yourself.
Dec 31, 2007 | Canon EOS Rebel T2 with 28-90 lens 35mm...
My canon Rebel 2ti shows message "cannot display
Sounds like your memory card might be dodgy - have you got another one to do a test on? What size is your memory card? 16GB are known to have problems.
Dec 31, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
How long has this camera been out? I'm shopping
The Canon Rebel T2i was announced on Feb 08, 2010 and Canon just started shipping the DSLR. Your salesperson was thus correct.
The DSLR is also known as EOS 550D. It differs from the previously model by:
  • Higher resolution 18MP CMOS with gapless micro lenses
  • ISO 6400 no longer in 'expanded' range (12,800 max remains the same)
  • Redesigned buttons and new movie/live view button
  • Customizable auto ISO ranges
  • Improved 63 zone metering (iFCL)
  • 3:2 format screen with more pixels
  • Improved movie functionality
  • Slightly higher burst shooting rate (though buffer holds fewer shots)
  • HDMI control (CEC)
  • SDHX Compatible
  • Apr 08, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Was everything set automatic?
    Was it a cloudy day?
    Did you take pictures in the sun of an object in shadow?
    Are your indoor pictures normal?
    If you are sure everything was OK, no shadows, no bright objects in the picture, ISO was not set 400, flash was not forced on, etc., call Canon. There are adjustments that calibrate the camera for outdoors. It may need to be recalibrated.
    Apr 02, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Pictures too dark
    Check your exposure compensation. It really sounds like someone set the camera to underexpose. This may be solved by removing the batteries for a few minutes. Other solutions are hitting the reset which will cancel all and return it to factory settings OR navigate to the exposure compensation settings and reset it there. If none of these solutions work, then the camera's internal program is messed up and its internal computer needs replaced.
    Dec 17, 2008 | Canon EOS Rebel T2 35mm SLR Camera
    Low battery warning
    What type of batteries did you buy?
    For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
    If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
    Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
    May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Canon EOS Rebel T2 300X Won't Autofocus or Take Picture. I can manually focus and take a picture, but when autofocus is on, it focuses for a second and then goes out of focus and won't let me snap a...
    This may be a problem with the autofocus itself, try the following:
    • If you have a different lens, see if the autofocus works with the other lens. If it does, there may be something wrong with your lens.
    • Clean the contacts (the little metal things between the lens and the camera) with a slightly moist, lint-free cloth
    • Try replacing the battery in the camera
    If none of this helps, you may have to take your camera to a qualified repair person to get them to have a look at it.
    Feb 25, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Canon eos rebel t2 battery indicator
    new batteries - brand new? fully charged per spec?
    Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
    Canon EOS Rebel G
    it seems you have a dirty lens,sticky mechanisms prevent smooth movement of lens cause by excessive moisture,blurry foto cause by fungus on your lens,pls note dissambling ang cleaning your lens requires patience and rigourous training.
    Jul 12, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
    Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera Logo
    150 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Are you a Canon Camera Expert? Answer questions, earn points and help others
