MONITOR ABCs
The monitor is a hardware device which physically connects to your
video card. The monitor allows information and current status be be visually outputted similar to a TV.
Like most TVs, the computer monitor has a CRT, or Cathode Ray Tube, which is found inside the computer monitor as illustrated in the above picture. The CRT is the main component and most expensive part within your computer monitor. Within the CRT are three electron guns, Red, Green and Blue. Each of these guns streams a steady flow of electrons, left to right, for each line of your monitor. As the electrons hit the phosphors on the CRT, the phosphor will glow certain intensities. As a new line begins, the guns will then begin at the left and continue right; these guns will repeat this process sometimes thousands of times until the screen has been completely drawn line by line. Once the phosphors on the CRT have been hit with an electron they will only glow for a short period of time; because of this, the CRT must be refreshed, which means the process will be repeated as explained above. If the video card's refresh rate is not set high enough, you may encounter a flicker or a noticeable steady line scrolling from the top to the bottom of your screen. If you are encountering this issue, resolutions have been described on our video card page.
MINIMUM RESOLUTION
The size is an important factor of the computer's running resolution. When picking the resolution, try basing it off the monitor's size for best use.
13-inch
640 x 480
15-inch
800 x 600
17-inch
1,024 x 768
21-inch
1,280 x 1,024
Hope this works for ya/Please dont for get to vote.
