If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Check the power supply for bad capacitors. These capacitors will be bulged out on the top. When caps go they cause voltages to fluctuate or even go away completely. This is a common problem for philips. Thanks
Testimonial: "Thank You so much for your help . I will recommend you to all my friends.Thanx again for your exellent technical support."
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
